Question about Kenwood KDC-116S CD Player
I have kenwood kdc116s and i have it running a subwoofer and i keep gettin voice through my sub and i need to know if the kenwwod has a low pass filter or a high pass filter
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Are there rcas on the back of the deck that say subwoofer????? if not then there is probably not . you can also go into the menu and see if it has subwoofer on/off.
Posted on Aug 31, 2010
How do I bridge a sub 12 Kenwood kfc-w3003
old school huh? Well those Kenwood subs are single voice coil so you can't bridge them to themselves like you can do with dual voice coil models. however, if you have two or more the speakers can be bridged to each other. You can wire them either in series or parallel. If you need instructions on how to do this just Google wiring two single voice coil subwoofers/speakers. There are plenty of detailed illustrations available on the web.
Aug 31, 2015 | Kenwood Car Audio & Video
I have 3 Kenwood 12'inch subwoofers need to know how to wire them up to a Kenwood KAC-9105D
Follow the link and use the first diagram which illustrates wiring the subs to 2.66 ohms http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~3~I~42
Remember that that amp is one ohm stable so you will not be getting the most out of that amp with that subs set up. The subs will only see 650 to 850 watts total...so each sub will only see about 215 - 275 watts a piece. Find out what the RMS wattage of your subs are each an determine if the wattage I mentioned above meets those requirements.
Sep 27, 2012 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Wiring Kenwood KFC-W3003
If it's a single voice coil, it's probably 4 ohms. the sub only handles about 175w RMS, so don't expect earth shattering bass to come out of it. A single voice coil is easy. Positive from the amp to the positive post of the sub, negative from the amp to negative post of the sub. This sub sounds lots better if it's in a sealed enclosure. A ported enclosure allows too much cone movement, heating up the coils, and the sub fails prematurely. Hope this helps.
Aug 25, 2011 | Kenwood KFC-W3003 Car Subwoofer
Hi ive got like music playing through my 12 inch sub aswell as bass im pretty sure subs are just their for bass. ive changed RCA cables i dont know how many times new amp sub head unit and power n ground...
Hello..... I can help you with this problem. You need a crossover to remove all of the high and mid frequencies from the subwoofer. If you run the sub at "full range" (all frequencies), you will destroy the voice coil. If your amplifier has a crossover on it, put it in the "low pass" or "LP" setting. If your amplifier does not have a built in crossover, you will need to add one. A crossover can cost as little as $29 for an electronic one. This will fix your problem. If you have any other questions, just comment back and I will be glad to help you!
20 year car audio/video installer
Bay manager
Mar 27, 2011 | Car Audio & Video
I have two 12 in. subs single voice coil and need to know if could run a 1 omh stablb amp and if yes and how
Yes, you sure could. Each sub is a 4 ohm load. When you put them in a box connect a wire from the + terminal on each speaker, and connect that to the + terminal on the box. Do the same from each - terminal, connecting to the - terminal on the box.
This is called "wiring in parallel" and it will split the load in half, so you present a 2 ohm load to the amp. Since your amp is rated down to 1 ohm, it will work just great.
Feb 07, 2010 | Kenwood 12" 4-Ohm Single-Voice-Coil...
How do you hook up a sub and amp to a stock radio with NO RCA outputs?
you can splice into the wires for your rear speakers and install some of your owns rca's and just use the low pass filter on your amplifier to eliminate the mids and highs from the frequency to your subs.
Jun 24, 2009 | Kenwood KSC-WD250 Car Subwoofer
Subwoofer moving wrong way possibly causing damage!
Hey i'm no expert either but maybe just maybe your amp has a subsonic filter on it which cuts out the lowlow bass maybe check that and either disengage it or turn it all the way down if it even has one thats all i can think of unless you have a ported box and going below the boxes tuning frequency other than that im as stumped as you are-good luck with it
May 08, 2009 | Car Audio & Video
I can hear voice out of my subs but they want through out bass
Check to make sure your amplifier is set to LOW PASS FILTER, not HIGH PASS. Make sure your settings on your head unit are set for full range, meaning 0 balance/fader.
Apr 22, 2009 | Car Audio & Video
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
Dec 10, 2008 | Kicker CVR12 Car Subwoofer
Kenwood KDC-116S CD Player Logo
75 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
