Question about Euro-Pro Easy Sewlution 385 Mechanical Sewing Machine
HOW TO THREAD THE NEEDLE FROM THE SPOOL TO THE NEEDLE
Can you send me a diagram (one that I can understand) showing me once step at a time to set up the thread so I can so.
  • Euro-Pro Master
  • 1,388 Answers
Try this link to Sewusa.com
They have threading instructions for several Europro models that may be similar enough to guide you, I am not familiar with this model as it was never released in Australia.
If you don't have the manual to refer to, your friendly local sewing shop may happily spend 5 mins showing you, of course their inclination will be enhanced if you are a regular customer !
Posted on May 12, 2008
My machine sews about 20 30 stitches and then the thread breaks at the needle. when I check the thread its showing me a single thread with the other thread as it separated
possible reasons include
old thread
thread too thick for the needle eye
needle not correctly installed where the thread runs down the small slot to the eye
needle thread tension too tight
needle /hook timing off a bit
Jan 08, 2017 | Sewing Machines
How to thread on a singer 4411. Thank you
To thread the upper thread, make sure that the needle bar is fully up, using the hand wheel. Put the thread spool on the spool pin and secure it with the spool holder. Use the end of the spool holder that is closest to the spool size. Bring the thread through first guide to the left of the spool holder. Slide it past and behind the guide before pulling it into the guide. Then bring the thread to the pre-tension spring. Similarly, the thread goes behind the spring and then comes forward. Next bring the thread down through the channel and up through the adjacent one further to the left. It helps to hold the thread between the spool and the thread guide. Once you bring the thread up through the second channel bring it from right to left through the slotted eye of the take-up lever. Bring the thread down and through the horizontal thread guide, the thin guide clamp needle and to the needle. Thread the needle from front to back.
The manuals for most Singer sewing machines are available from the manufacturer's site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 4411 is http://www.singerco.com/uploads/download/1230_4411_heavy_duty_esf.pdf . See page page 16 (page 23 of the PDF) for pictures of the guides.
I hope this helps.
Jan 05, 2017 | Singer Sewing Machines
Bernina artista 180 bottom stitch bunching
bunching under the material is bird nesting is a result of loose needle thread tension thread the machine up to the point of threading the needle
pull on the thread and you should have a reasonable resistance to pulling the thread
adjust the tension until you get that then thread the needle
while you may be using the tension settings if there is a problem in the tension plates area , the tension will not get high enough regardless of the indicated setting
bobbin tension can be reasonably loose
correct tension is when both threads meet at the center of the materials being sewn
May 25, 2017 | Sewing Machines
Threading a bernina
Depends on the model, for detail but basically: Ensure the takeup arm / needle is at the top of its motion - with electronic models this is easiest done just by 'blipping' the foot controller and the needle will automatically return to top. Put your spool of thread on the spool pin. On older models with the vertical spool pins ALWAYS use a felt pad underneath to prevent the spool spinning when the thread is drawn off. On later models with a horizontal spool pin, hold the spool in place with the correct size retainer, with the larger diameter facing away from the spool. Make sure the foot is up (this is important). Draw thread off the spool and route it through the pre-tensioner on the back of the machine, then through the slot until it passes through the tension discs next to the tension control. The thread is then brought down the right-hand-side of the takeup arm cover, and pulled-up the left-hand side (it should be pulled into the check spring at the bottom, automatically. Pass the thread around the right-hand-side of the takeup arm and then the left-hand-side so that the thread is left running through the takeup arm. Drop the presser foot. Route the thread behind the lower thread guide at the bottom of the takeup arm cover and then through the thread guide at the bottom of the needle bar, just above where the screw that retains the needle is situated. The thread guide might be a simple loop of wire or a clip on the botom of the needle bar. Thread the thread through the eye of the needle either manually or using the needle threader, if fitted and off you go. It's important to have the foot raised when routing the thread through the upper tension discs to make sure the thread sits properly within the discs rather than just going over the top of them. Raising the foot holds the tension discs open.
Jun 29, 2012 | Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
I hava a Janome 393 Sewing Machine which I got down from Middle East. I lost my manual on my return. Though the machine is new but it is skpping stitches. I shall appreciate if you guide me how to feed the...
First simple fix would be to change the needle for a fresh sharp one, the right size for the fabric you are sewing. Blunt or burred needles will cause poor stitching, missed stitches and often a popping or squeaking sound. New needle for every 4-6 sewing hours is the rule of thumb. I put in a new one for each new project and that way, I know it is fresh and the appropriate size and type. Use ball point needles for stretch fabrics and regular needles for woven fabrics.
I can not see a threading diagram for your machine on line but this site http://sewing.about.com/od/sewingmachineindex/ht/threadmachineht.htm has good step by step instructions and also photos identifying the important parts of a sewing machine. They vary between makes and models but once you understand what each part does and how the stitch is formed, it is straightforward to thread up an unknown machine as they always have a similar path from the spool, to tension device, to a take up lever, then to the needle. Same applies to the bobbin, whether it is top loading or horizontal. There is a right way to put in the bobbin, and always some sort of tension spring or device which controls the release of the thread from the bobbin during stitching.tally_girl_37.jpg I can not find a 393 image either but here goes on the above image. Put the thread onto the spool pin on the back of the machine, right hand side. Sometimes the pins are retractable and need to be pulled up, others are fixed in place. Take the thread tail from right across to the left side and around the thread guide on top of the machine, the little metal hook, then down the front of the machine on the right hand side of that long dark green panel, at bottom, reverse direction and take back up the left hand side and catch thread into the take up lever. You can't see it in this photo, turn the fly wheel towards you until it raises up to its highest point and thread or pull the thread into its open end. Now back downwards towards the needle. There is usually a thread guide on the needle bar, hook thread behind this, then thread the needle and pull a tail of about 10 cms out under the pressure foot and to the back.
Now thread the bobbin, clicking the thread tail into tension spring. On many Janomes, the bobbin cover is a clear plastic piece and has an image showing the right rotation for the bobbin to make things easy.
Now turn the flywheel towards you holding the top thread tail firmly, go through one downwards movement with the needle, then back upwards again and pull the thread tail, catching and pulling the bobbin thread up to the top of the needle plate. Both threads under the foot and out the back and your ready to sew!
Jun 22, 2011 | Sewing Machines
How to thread the machine.
http://www.instructables.com/id/How-to-Thread-a-Sewing-Machine/
check out this link.. it is described clearly with the help of images...
OR
try to do by reading these steps..
Step 1 Raise the needle to its highest position by turning the handwheel toward you.
Step 2 Raise the presser foot. This will allow the thread to easily pass through the threading points and will prevent the machine needle from becoming unthreaded when you begin to stitch.
Step 3 Place a spool of thread on the spool pin located at the top of your sewing machine. If the spool pin runs horizontally, secure the spool of thread with the cap provided.
Step 4 Take hold of the thread end and pass it through the designated threading points on the top of the machine casing, then down toward the tension assembly. The tension assembly is located on the left side of the machine and controls the flow of thread.
Step 5 Take the thread under the tension assembly and back up through the next threading point at the top left of the machine. Make sure the thread has passed between two tension discs as well as the hook that may be attached to the left side of the tension dial.
Step 6 Push the thread end through the lever at the top left of the machine, if applicable, and down through the threading points at bottom left and above the needle.
Step 7 Thread the needle from the front or back of the needle. The threading direction will depend on your machine type.
Step 8 Pull a few inches of thread through the eye of the needle and pull the thread to your left.
Step 9 Insert a wound bobbin into the machine, if necessary, and close the throat plate. A few inches of bobbin thread should be pulled out to the right and sticking out from under the closed throat plate.
Step 10 Take hold of the thread that has been threaded through the machine needle.
Step 11 Rotate the hand wheel toward you until the needle disappears into the bobbin case.
Step 12 Keep holding on to the thread and move the hand wheel so the needle is once again at its highest position. As the needle rises, a loop of bobbin thread will come up as well.
Step 13 Pull the thread out toward your left to draw the bobbin thread loop further out of the bobbin case.
Step 14
Let the top thread go and pull the bobbin thread up until the end comes up. Pull the top and bottom threads under the presser foot and to the back and right of the machine.
please rate this solution...
gkgb.
Jan 13, 2010 | Sewing Machines
I cant remember how to fill the bobbin with thread :(
Insert the empty bobbin case onto the bobbin winder in the sewing machine.
Step 2 Set the spool of thread onto the thread peg. Use the same thread you want to use on your material to obtain the best finished stitch.
Step 3 Follow the arrows or guides to take the thread from the spool to the empty bobbin.
Step 4 Start the thread around the bobbin in a clockwise direction.
Step 5 Push the small lever against the bobbin spool to hold it in place. This disengages the needle so it won't go up and down while winding the bobbin.
Step 6 Press the foot or knee pedal to start the winding process. Stop when you have enough thread on the bobbin for your project.
Step 7
Cut the thread between the thread spool and the bobbin. Insert the bobbin into the bobbin case so you can begin sewing.
Open to clarifications.
rate this.
Jan 10, 2010 | Janome Jem Silver 662 Mechanical Sewing...
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Threading Diagram
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Aug 31, 2008 | Sewing Machines
Euro-Pro Easy Sewlution 385 Mechanical Sewing Machine Logo
463 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
