Question about ASUS P7H55M PRO (90MIBBB0G0EAY0KZ) Motherboard
I I just bought a Asus p7h55-m pro motherboard and when i boot my computer my screen says overclocking failure please press f1 can u help me with this problem
    President:
  • 2,571 Answers
Go into your bios and restore settings to default.
Something you have changed is preventing windows from booting.
If you have not changed anything, you may need to download the latest bios for your motherboard. check here http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Aug 31, 2010
I've had my Asus p7h55-m pro motherboard for a year now at its worked fine but recently when I boot my computer its struggling to load and very rarely gets past a screen displaying the motherboard...
I am not sure about this solution but it sounds like your registry is corrupted. Try going to http://www.instantfix.net pc error support for registry recovery. Disregard the sales pitch and go to option 2. Manual Repair, Manual steps to recover a corrupted Windows registry. It requires that you follow the directions very carefully. What operating system are you using?
Sep 28, 2011 | ASUS P7H55M PRO (90MIBBB0G0EAY0KZ)...
Asus p7h55-m lx Trying to load server 2003. System starts to load at about 36 minutes left system shuts down and re boots tried New mb New chip New memory Call ASIs support they d Couldn't help...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 29, 2011 | ASUS P7H55-M LX Motherboard
I bought P7H55-M motherboard. I try to install soundcard (2-cards) E-mu 1212m, but always when I try to install drivers it says that it will stop installation since it doesnt find any hardwareto fit with...
The P7H55-M motherboard has on-board audio and connections to the audio on the rear connections including a S/PDIF connector. If you want to install a soundcard then you should first disable the on-board audio controller in the Bios.
Dec 26, 2010 | ASUS P7H55M PRO (90MIBBB0G0EAY0KZ)...
Hello! I would like to know how to disable the onboard video card on Asus P7H55-M Pro mainboard... could you helo me please? thanks!
Hello ,
Just go to the bios settings and find the option to disable the onboard video. But make sure to that your booting video is pci.
You can set those options in bios settings.
To go to bios settings.tap the del key or f1 or f2 key continiously the minute you turn on the system.
If something goes wrong try removing the small battery cell from your motherboard and fix it back again in 5 min.
Oct 21, 2010 | ASUS P7H55M PRO (90MIBBB0G0EAY0KZ)...
It says cpu voltage error pls press F1 and i did it but instantly swiches off why? pls help me
and do you still have anny errors? when did this occur, after overclocking?
please some more info :)
Jan 12, 2010 | ASUS P5LD2-VM Motherboard
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Sirwriter
Nov 05, 2009 | Intel DG31PR Motherboard
OverClocking Problem when startup my system
Most motherboards have settings that allow the board to try and overclock itself upon bootup. Take a look in your manual and it should lead you to the correct setting in the bios that will allow you to have the computer boot up in normal mode. Failing that, you may have to force the motherboard back to the default setup. There is a jumper you would have to move, then you would remove the battery from the motherboard. Check your manual for how to clear the CMOS settings if you need to do that step.
Jul 10, 2009 | Computers & Internet
Worried about failure rate of asus p6t deluxe v2 motherboard heard it has a 50% failure rate
No that is not true. Though the percentage is higher if you try to overclock on that motherboard. As long as you don;t do any overclocking you should be fine.
Apr 26, 2009 | Computers & Internet
Please god help me.
Did you upgrade your heatsink and fan when you overclocked? If not, your cpu probably got too hot and burned up.
Sep 03, 2007 | ASUS A8V Deluxe Motherboard
ASUS P7H55M PRO (90MIBBB0G0EAY0KZ) Motherboard Logo
403 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
