Question about Sears Garden
I need to replace the voltage regulator on my 1968 Sears SS 12 lawn tractor but do not have a part number or other information to order one from my local auto parts store. The engine is a Tecumseh.
  • 109 Answers
SOURCE: Sears lawn tractor-25 horse Kohler engine-revs won't slow down!
The governor will need to be replaced
Posted on Apr 24, 2009
wadembly
  • 448 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
  • 154 Answers
SOURCE: Looking for a owners manual for a sears craftsman lawn tractor.
did you try ebay?
Posted on Jun 08, 2009
mowerman1857
  • 389 Answers
SOURCE: Sears lawn tractor tubeless tire replacement
Most local tire shops have or can get tires and tubes of the size you want/need and would install them as well. Without the proper tools, they can be a "bear" to change but if you insist upon doing it yourself, go to a GOOD lawnmower repair shop and have them order the sizes for you. It has been my experience though, the tire shops are cheaper
Posted on Sep 14, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
On the 1967 sears super 12 tractor what part number replaced sears part number 606A190 for the voltage regulator
you have a starter generator... you can go to most specialty 12 volt shops ( starter re-builder ) or online and find a good quality universal V.R. can't remember if thats a 6 or 12 volt system... google 12 volt external voltage regulator and you will get an idea what I am talking about. I've done this repair a number of times
Oct 23, 2014 | Garden
Battery will not charge on Farm 1940 Farmall Cub Tractor it is not a lawn mower
check voltage at with tradtor running pull off pos side of battery see if your getting voltage for 6 volt 6.5 to 7.5 volts for 12 volts 12.5 to 13.5 if low voltage go to voltage regultor if volt or low go to generator test there if low replace gen if voltage ok generator replace voltage regulator
Sep 02, 2014 | Garden
I need a wiring diagram for sears model 917.272066 riding lawn mower
Should contact SearsPartsDirect.com,they have all the wirings on all their Craftsman lawn tractors. There is another way you might find a wiring diagram. Look in back of your Owner's Manual,i have found a wiring diagram & part numbers to include,the whole tractor is broken down in a diagram format. There are other lawn mower shop that should have a wiring diagram,i.e. AMCParts.com. Hope this helps.Sincerely,Brad Locke DTD 12/04/15
Oct 27, 2012 | Sears Garden
Missing pin that's in the deck adjustment handle. Need a replacement part
If it is the pin that engages the teeth when you release the thumb button on the lift lever the Sears part # is 105767X. Get the 9 digit Sears model number from under the seat and then you can verify & order the part at www.searspartsdirect.com
Oct 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Problem for Craftsman 20 hp 42 in. Deck Lawn Tractor - ca model wheel alignment: both wheels point outwards
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Husqvarna lawn tractor 48" model yth2448. My batteyr will not recharge and I must continuously relpace batteries. My diagram shows a regulator and alternator but doesn't give me product numbers so...
When your tractor is running check the voltage at the battery posts with a meter. If the voltae is above 12 you are chrging good and need to replace the battery. If it is lower than 12 then the regulator and altinator are next. Remove the regulator and you will find numbers on it to take to a dealer and replace or have checked. Do the same with altinator..it could be either so give it your best guess in the order you want to have them checked. On a personal note..check your ground wire from battery to frame and make sure it is tight and clean. :) Hope this helps.
Sep 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I need replacement blades for a Craftsman LT1000
get part # or model# from owners manual and go to sears.com and order or stop into a local sears with the numbers and theyll set you up!
Sep 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do i replace the lift shaft assembly on my craftsman lawn tractor? model number 917.272442.
there is not enough space here to describe the replacement procedure. some helpful tips though - order the part you are replacing [ordering from sears tell them: division 71, source 917, part no. 159471] before you tear into it. sitting around for 3 or 4 weeks, you'll probably forget where things attach. also, find the exploded parts diagram in your owner's manual and look it over carefully to see what you're getting yourself into. sometimes, it's worth a few bucks to let a competent shop do the work
Jul 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need parts manual for Craftsman 22HP 50 inch deck lawn tractor
Go to "sears.com", have your model number ready and go to the parts link. You will beable to view an exploded view of your mower and order parts on line if you like.
Hope this fixes your question, let me know.
Regards,
Jun 12, 2009 | Garden
Garden Logo
123 people viewed this question
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
