Question about IBM Refurbished - AS400-9406 POWER SUPPLY UNIT MODEL 064 (21H9364) Power Supply
My AS400e (9406-170) booted with the following error code 10112564 which suggests that it needs a power supply. Do you suppy this item?
    Problem Solver:
  • 14 Answers
Go to ebay and search for ehardwareforless seller
Posted on Jul 02, 2011
Asus P8C WS error code 55
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
When a computer completely fails to boot or to provide any sort of power on self-test (POST) beep codes, the cause is either a hardware failure, lack of power or a bad connection.
To solve these problems, it helps to start with potential environmental causes first, such as a problem with the AC power being supplied to the computer.
From there, a good rule of thumb is to simply start disconnecting items from the computer one at a time until just the CPU, motherboard, RAM and power supply remain connected, and then swapping in known good replacements for them.
Test the AC power to make sure there is power to the outlet. Inspect the back of the power supply to ensure the power cord is fully seated, the power switch is on and the voltage setting is set to the right voltage, which is typically 110 volts.
Inspect the inside of the computer for any signs of burned components, such as capacitors or integrated circuits that are deformed or discolored, and replace the affected expansion card, motherboard, drive or other device if damage is located.
Verify a proper connection for each expansion card, cable, drive and stick of RAM by disconnecting and reconnecting each item without removing it from the system.
This can sometimes clean corroded or loose contacts and solve minor problems that prevent the system from booting.
Disconnect the drives and remove all of the expansion cards except for the video card, and try to boot with a bare system composed of only the power supply, motherboard, CPU and cooling fan, RAM, and video.
Attempt to start the computer again. If the system boots, reinstall the removed items one at a time until the system again fails to boot, and then replace the component that is causing the failure.
If the bare system fails to boot, swap in known good components for the motherboard, RAM, video card, power supply and CPU until the system boots.
Swap components into a working computer one at a time until that system fails to boot in order to locate problem components.
Hope this helps.
Nov 22, 2012 | ASUSTeK COMPUTER ASUS P8C WS - Motherboard...
Fix error code 00893947 on Hp officejet G85xi
Error 00893947 may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer. Follow these steps to fix your problem: It is highly suggested that you carry out all the steps in exact manner to effectively get rid of your problem. Scan the Computer with Reimage Repair Tool This repair tool is free to download as well as easy to use. It scans, detects and repairs your computer for system errors like Error 00893947. The tool is powerful enough to find malicious items that are hidden on the computer.
Aug 01, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
I sent i a question yesterday .Still I'm unable to
If the screen shows running in lower power as an error. I think your powersupply isn't supplying enough power to the computer, and probably needs to be replaced.
May 11, 2011 | Gateway Computers & Internet
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
I have an eMachines T2200 The power supply started making noise and I shut the system off. The next time I tried to boot up nothing happens. I replaced the power suppy and when I turn it on the cd and dvd...
I would check to see if power is getting to your hard drive, Make sure the white molex's are plugged in.
E-Machines are, unfortunately the worst machines out there. They're up there with Compaq.
You're not going to like what I say but I'd urge you to buy a new one. Chances are it will take an arm and a
leg to fix what your using and for a little bit more money you can have a really nice one for 500 dollars
or less.
Dec 31, 2010 | E-Machines eMachines Desktop PC
Power button lights up but desktop will not boot. Appear to bad power supply
Change out power supply with a computer that has worked in the past and has a similar power, supply. Check power supply for 5volts,12volts we are black box specialist noone dors this any more change out power suppy and see if it works
Nov 24, 2010 | Gateway GT5404 PC Desktop
Eee pc 1005 series wont boot up
There is no clarification pf sysmtoms in the problem reported but can suggest following steps:
Whether power is coming in the machine?
If the power is coming and system is restarting at manufacturers logo then this might be the issue with the mainboard.
No Power
Might be gthe issue with mainboard or the power supply.
Power but not booting or any error message is coming?
The OS is currupted and reinstallation is needed.
Please text for any clarification.
Thanks
Mar 09, 2010 | ASUS Computers & Internet
GT5014 won't boot
Generally this means there is a problem with the power suppy as it is not giving a correct voltage to the motherboard to start the computer. check your fans on the power supply, make sure they start when you try to start the computer . A power suppy may be purchased and installed fairly easy. and you should spend no more than 50 dollars on the parts.
Mar 05, 2009 | Gateway GT5014 PC Desktop
Computers & Internet Logo
360 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
