Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a LT4000 riding mower it will not start. i have to jump it at the starter.
    Novelist:
    Sniper:
  • 71 Answers
I'll answer this for future concerns. Assuming you have the clutch/brake pushed in and the blade/attachment lever disengaged, power should travel from the battery positive cable through the 30 amp fuse located in the area near the solenoid and into the B pin of the ignition switch. When the key is turned to the start position, power will travel to the S terminal of the ignition switch into the white wire and into the brake pedal switch. It will then flow out of the brake switch into a white wire and into the attachment/blade switch. A white wire out of the blade switch goes to the solenoid. This white wire activates the solenoid, allowing power to flow through the large battery cable and into the starter motor. The best way to diagnose is to check for power at the ignition B switch terminal. If power is present turn the key to the start position and check for power at the S terminal. Continue following the white wire until you lose power. My tractor had a bad ignition switch confirmed by a lack of power at the S terminal. If white wire is traced all the way to the solenoid with power present at the its terminal, the solenoid is faulty.
Posted on Sep 29, 2012
  • 148 Answers
Have you checked the solenoid? Does it click when you turn the key? If not then check the solenoid by taking a long screw driver (with a rubber handle) and short between the post if it attempts to start then your ignition switch is bad if not then the solenoid is bad.
Now all of the above assumes that you verified that your battery is good.
Posted on Aug 31, 2010
Why wont my mower start after replacing battery and solenoid and i tried jumping straight to starter?
sonds like bad starter especally if you jump the starter nothing happen check for blown fuse behind dash check the starter switch trace the wiring look for bear spots but i think its the starter or blown fuse
Aug 26, 2014 | Garden
Tractor won't turn over. Replaced Battery, starter and hotwire to starter getting smoking hot while trying to jump the tractor or start the tractor.
Is the engine free to rotate? Can you move it by hand? If not, the starter can't.
If so, try removing the plug and starting it.
Gary
Jul 24, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I need a manual for oem 190-620a snow blade
did you get your manual or not i have one that i can copy and fax you if you still need one
Sep 06, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
Instructions for replacing deck belt for craftsman2 12.5 hp riding lawn mower
when engaging my blades on my craftsman lt4000 12.5 hp lawn mower the pullys wont engage them
Apr 17, 2010 | Craftsman Garden
Replacing belts on sears lt4000 42 in cut?
Hi..my name is Keith..and you can go to an online lawn mower parts site...and they will have a parts diagram of the deck and drive belt..one if the sites is.. www.outdoordistributors.com ..i hope this will help
Jul 08, 2009 | Garden
Mower won't start
sounds like the ground cable is bad
Jun 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
May 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
312 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
