Question about KitchenAid Refrigerators
Strong smell coming from vent in both side of refg. smell like chemicals i have removed every thing and clean also use baking soda
  • KitchenAid Master
  • 17,130 Answers
Possible that the fan is burning or the heater is burning or there is a gas leak. Put the fridge off and notice if the strong smell comes off. If so it can be even if the motor windings are hot or the capacitor is leaking but that would be only on the outside.
After the fridge has cooled off , clean the vents after opening the freezer covers to get access to the vent fan. checck for any signs of smell inside , if so you can identify but also check if of the components are hot .
Now use a good perfumed cleaner, use of baking soda is also good , but by smeeling if you notice that the smell came from the vent, keep an open view.
Now put the frdge back in action and check, this time your senses can guide you to the fault area.
This first hand info must be the guide but what needs to be done if the smeel is starting to come from the vent is to get access to the point of intensity to finalise. It can be the fan or wires shorting with frost on the plastics.
comment after review
Posted on Aug 31, 2010
Chemical smell in kitchen. is it coming from my brand new refrigerator?
the odors are normal for some new refrigerators,its due to the type of plastic used,let it cool and put coffee inside both compartments or baking soda as these 2 items will remove odors,after the odors gone continue to keep a box of baking soda in each compartment to control all food or plastic odors,this should help remove your odor problem
Feb 12, 2013 | Whirlpool Refrigerators
We cleaned out fridge inside and out put in baking soda and coffee turned it off let it sit and we still have a smell in it whats the problem
its that darn coffee you put ith the baking soda causing the smell,wash it out again only this time only use the baking soda by itself,,, NO COFFEE!
and leave the door open for it to dry out, that should sort out the smell,,,,why did you use coffee with baking soda???? it causes it to smell bad?
Nov 14, 2009 | Hotpoint HSS25GFP Side by Side...
Odor in GE side by side Fridge
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Bad Smell in Fridge
To remove odors:
1. Remove all items from refrigerator or freezer. Throw
out any spoiled foods. Take out removable parts and wash
them and door gasket with mild detergent in warm water.
Rinse well and wipe dry.
2. Wash interior walls and door liner with solution of 1-2
tablespoonsful of baking soda to 1 quart warm water, and
wipe dry. Leave door open and let it air out well, with a
fan directed toward inside, and opened windows if climate
permits.
3. If odor still remains, try one or all of the following
means of odor removal.
a. Spread baking soda out on shallow pans (like shallow
glass casseroles, pie plates, or jelly roll pans lined
with foil) and put pans on shelves to absorb odors, or on
the bottom and in baskets of chest freezer. Leave open
and unplugged.
b. Buy activated charcoal (which is specially treated to
remove odor molecules from air) at some department store
housewares sections, appliance store, or pet shop. Spread
out on shallow pans and put on shelves of refrigerator.
Turn refrigerator on low setting and run empty a few days
so odors will be absorbed.
c. Spread cat litter in shallow pan in cabinet, turn on
and run empty a few days. If odor is disappearing but is
not all gone, replace old litter with fresh litter.
d. Pour several ounces imitation vanilla (not pure
extract) in a shallow saucer, put on shelf and let run
empty a few days.
e. Put fresh ground coffee in cereal bowls inside the
refrigerator and let run empty several days. A slight
coffee odor may remain, but will disappear after washing
again with baking soda solution.
f. Pack each refrigerator shelf with crumpled newspaper.
Set a cup of water on the top shelf or sprinkle the
newspaper lightly with water. Allow refrigerator to run
for approximately 5-6 days. This method takes a bit longer
but has been effective in removal of strong odors.
g. Buy a commercial odor remover, and follow instructions
exactly. Several companies manufacture a liquid
concentrate which sells for about $3.00 for 1/4 to 1/2
ounce. A couple drops are put on a piece of cotton and
placed in the area to absorb odors, in the cabinet or
in a room.
Three of many brand names are: "Odor-Away" by Wrap-on
Co., available at hardware and hospital supply stores,
"SuperCD" IBL Household Products by Crackerbarrel Sales,
Avenal, New Jersey, available in pet supply department
or special products in grocery, or "Clean-Air" at some
appliance repair shops.
Hospital supply stores carry Dow Chemical Hospital
Disinfectant and Deodorant Spray. Spray into cabinet and
quickly shut the door. Repeat.
4. If none of these methods removes all the odor, then it
has probably penetrated into insulation. Contact an
appliance service company for an estimate on cost of
removing the liner and replacing the insulation. If cost
is too high you may prefer to get a new appliance. It
could be used for occasional cooling of soda pop where
the odor will not get into the beverage.
Chemical odor...
from where does the smell come?
inside the unit or from the body?
does the smell spread to food items?
Jun 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Smell from under the side by side.
mix a solution of baking soda and water, open freezer section and right at bottom fofreezer back wall you seee vents cut in plate, they lead to draintube and eventually to drain pan(which in most new models is not removable) pour the solution down the drain(maybe a cup or so), the waterwill evaporate and the baking soda will remain absorbing odors
Feb 21, 2008 | Jenn-Air JCB2388G Side by Side...
Chemical odor...
Is the unit working ok I think tech17 is trying to find out if you have a freon leak inside the unit??
Jan 18, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
124 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
