Question about InFocus LP70+ Multimedia Projector
My projector doesn't show red . it shows red as black..?
5 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: SHARP XG-P25X PROJECTOR PROJECTOR RUNNING
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
Posted on Aug 04, 2009
projdoc
  • 2237 Answers
SOURCE: projector lamp shows blue on white screen
the red is cutting out. white=blue+green+red. without red, you get blu+green, or cyan. if this was an lcd projector, i'd say it's a burnt light filter, the red lcd, or the lcd has come unplugged. but since this is a dlp projector, you have either a dmd board issue or a main board issue. either way, it'll be pricey.
Posted on Aug 18, 2009
jahting
  • 70 Answers
SOURCE: Projector shows wrong color
change your vga cable...
Posted on Oct 08, 2009
  • 269 Answers
SOURCE: The projector does not show
It could be 3 things--
1. You need a new cable
2. This is unlikely, but the red segment could be off the colorwheel, but if this was the case the wheel would be way out of balance and the projector would be vibrating like crazy.
3. The "color ramps" or colorwheel index in the hidden factory menu may need to be adjusted.
Posted on Sep 16, 2010
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
When we do a presentation the Red shows black and orange shows green what can be the issue
have you selected the colour mode,
sRGB: Matches the color palette of standard sRGB computer
displays.
Feb 23, 2011 | Epson EX51 Projector
The projector does not show the color red. It shows it as black or on a black background shows nothing at all. Can you help?
Sep 15, 2010 | InFocus LP70+ Multimedia Projector
My InFocus 4805 SP projector is showing just black and white
If you have any video at all and it's only Black and white there is a 99.99% chance that your Color Wheel has lost all of it's glass color filters.
You can confirm this by removing the lamp. then look straight into the projector where the lamp was and you should see the color wheel of colored glass segments (Red, Green and blue) I believe you won't see them because they came off of the wheel.
Also if you lift up the projector and turn it around in various angles and you will hear the small pieces of broken glass from the color wheel.
Unfortunately you will need to take it to an authorized service center for repair. Be prepared to spend upwards of $300 for the repair.
Cheers
Aug 23, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
Proxima dp100x projector shows red background. Is
the colorwheel or the dmd chip may be bad. but first, go into the menu under service and reset the settings to factory default.
Aug 21, 2009 | InFocus Proxima DP1000X Multimedia...
Projector lamp shows blue on white screen
Feb 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Red does not show up
You have a break in the VGA feed to your projector, try another lead and try menu see if it is missing from there if not it is the lead.
Marc Engineer
Feb 13, 2009 | NEC VT570 Multimedia Projector
Projector is showing red as black
red Lcd panel is failing, your cable is bad, or broken pin on input.
Oct 23, 2007 | Panasonic PT-LB10VU Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
1,272 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
