Question about Fisher and Paykel DG05 Gas Dryer
Dryer is squeaking when running. how many slides of each color are needed to repair it? and might I find a manual on how to replace them?
  • Fisher and P... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 04, 2010
Squeaking Cabrio dryer when running
The squeaking is due to the drum glides or as some people call them slides, being worn or broken. Easy fix and very inexpensive part
Mar 25, 2014 | Whirlpool WGD8800YW Cabrio Platinum High...
Squeak when running
It is either the drum slide, or the bearing that need to be replaced. Here is the slide you may need. Here is the bearing kit.
Jan 10, 2011 | GE DBXR463EDWW Electric Dryer
Dryer squeaks and pinches/burns clothes. Someone looked at it and said there was a worn down pad that sits on top of drum. Need to know the part name. Thanks.
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Aug 21, 2010 | GE DCSR483EA Electric Dryer
My dryer is making a loud squeaking noise when it
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 27, 2009 | Dryers
Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Mar 23, 2009 | Maytag PYE2300AY Electric Dryer
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Jan 07, 2009 | GE DBSR453EBWW Electric Dryer
Dryer drum causing squeak
Most likely the front support bearing. If this is the problem you will likely have to replace the slides too. The wizards have a ten year warranty. The bearing is part number WE3M26 and the slides probably need 3 or 4 of them are we1m333. Hope this helps.
Dec 11, 2008 | GE Profile Wizard DPSE592EAWW Electric...
There is a squeaking sound when running the dryer
Follow this link and click on pruduct manuals or search this page. If you can not find it contact customer service. I hope this helps you.
Nov 28, 2008 | Frigidaire GLEQ2152ES Electric Dryer
GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Sep 17, 2008 | GE Profile DPSR473EW Dryer
Fisher and Paykel DG05 Gas Dryer Logo
196 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
