Question about Sharp AL 1631 Copier
When i close the back door it is making a loud noise. sharp al 1631
  • 61 Answers
If it sounds like gears grinding it may be the fuser unit. The bushings and gears need replaced or new fuser unit.
Posted on Aug 31, 2010
I am getting a ch message on my sharp al-1631 copier and can not find the manual. Do you know what this means?
CH stands for close hatch check that the front and side doors are closed. (open both then close again)
Jun 21, 2011 | Sharp AL 1631 Copier
MWe have a sharp al-1631, only used for coping of documents. It has been a great! machine and still serves us well. But it is making a very loud grinding noise, almost like nylon gears grinding (I...
Odds are, that the fuser driver rachet gear is stripped out and you may also have a broken gear on the upper fusing roller. It could be one or both..... You will have to take the fuser unit out and look at the gears. If you do take the fuser out.... Unplug the copier from the wall...... There are just two screw that take the fuser out, you will have to take off the back cover to unplug and remove the fuser unit.... Good Luck
May 19, 2011 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
I have a sharp copier AL 1631- it's making a noise
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Feb 08, 2010 | Sharp AL 1631 Copier
Sharo al 1631 makes clicing noise and does not
Sounds like your scanner is jammed or the scanner motor has failed.
If you are so inclined, turn the power off, you can remove the glass and try to move the scanner by hand, if you can't move it then it is jammed, if you can move it to the middle and turn the machine back on, does it return it to its home position? if so, the motor may be OK, but the control board may have a problem, if not, the motor have likely failed.
Hope this is of some help.
Ed
Apr 30, 2009 | Sharp AL-1655CS Copier
SHARP COPIER AL-1631
2 things:
1. Fusing Unit has to be replaced- worn or broken gear
and/or
2. Main Drive clutch has to be replaced.
Either way it has to be done by a trained technician.
Dec 24, 2008 | Sharp AL 1631 Copier
Green blinking light CH
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
128 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
