Benq fp71e turn on for 2 seconds
  • 1 more comment
  • bejars May 10, 2008
    it turns off complitly, no action !
  • thunder1979 May 27, 2008
    Yes, what do you think the problem might be.
    Simon
  • and what hapens? screen black?
You have a virus
Posted on May 09, 2008
Have connectd benq fp71e moniter it works good but no sound from moniter speakers
Try on putting a headphone jack similar to the the image:
Put it on back of your monitor's audio slot. It is usually colored green and then put the other end to your computer audio slot. Thank you
Sep 16, 2011 | BenQ FP71E
How to get sound working on a Benq 17" FP71E?
is on the back audio input connector, and you can set audio levels on the monitor menu items.
Nov 06, 2010 | BenQ FP71E 17" LCD Monitor
When I try to turn the BenQ FP71E 17" LCD monitor on, the on/off button glows blue for around 1 second, the monitor screen comes on for around half a second and then they both turn off simultaneousely. Any...
Since Dell monitors are made by BenQ, please look at Dell photo albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | BenQ FP71E 17" LCD Monitor
BenQ FP71E turns off after 2 secs- Logo flashes then turns off
LCD monitors behaving in this fashion more than likely have a faulty inverter. Refer www.lcdparts.net for solutions.
Sep 13, 2009 | BenQ FP71E 17" LCD Monitor
Benq FP71E, No Image Displayed
Try checking the settings in properties for this device to make sure they are as you left them. YOu can also uninstall the drivers for the card and reinstall them to see if that takes care of the issue.
Jan 05, 2009 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17 - how to open
There are 4 pieces 2 each around yellow invertor transformers.
Check visually for darkened back of the transistor.For reliable testing you need to desolder and test with an ohmmeter.Also check the FET Fu9024 or D10Pf for similiar problems.
What is your actual symptom?
Samir
Aug 20, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17 goes black during post
Hi...there,
With AC adapter it's to your left, a rectangle piece. Without, it's under you power supply w/ built-in inverter... the capacitors look like a tiny battery on the side it have voltages size ( example like 1000uf 16v ) Good lucks, have a nice day!
Half Display
That Seems to be a panel problem.Benq provides 3 year warranty,Try contacting local BenQ service centre in your country.
Samir
Aug 11, 2008 | BenQ FP71E 17" LCD Monitor
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Power but no picture
Try to re-solder the inverter part of the board. You may recognize that part where the 4 connectors from the backlight tubes can be found.... usually the small transformators (sorry, my technical English is not good) have bad soldering eyes after longer use. This may work if backlight turns on for a few seconds, then the power led is still alight but screen goes dark.... the inverter then "thinks" one of the tubes might be defective and turns power off. Hope this helps a little...
Jun 20, 2008 | BenQ FP71E 17" LCD Monitor
Computers & Internet Logo
547 people viewed this question
David Payne
David Payne
