Question about Kenmore Washing Machines
Water run over top of tub - Kenmore Washing Machines
    Champion:
  • 245 Answers
What has happened is your water diaphram has gone bad. If you look at your control board you will see your water select switch. This is the water diaphram. Remove the two side plastic covers from the control board. Remove the two screws underneath the plastic covers. Flip control board over. Make sure the diaphram hose is still connected before you order a new one. If the hose is connected at the diaphram than the diaphram is bad. To replace the diaphram, Unplug washer, remove hose, plug, and twist to remove. I hope I helped you.
Posted on Aug 31, 2010
Only hot water makes it to the tub. I can hear cold water running. I can feel it traveling through the hose, but it does not get into the tub. Why (and where is the cold water going)?
hmm...so you're certain that the cold water is actually going in someplace huh? ok, try this...run it like you have it now...put your hand in the water flow and feel how hot or warm it is...now turn off the cold water and see if the hot water gets hotter...if it does,then try the opposite, turn off the hot water and see if there is still water coming into the tub...let me know what happens
Jun 10, 2012 | Maytag PAV2300 Top Load Washer
I have a Kenmore 500 top load washer that doesn't hold water. As it is filling for the wash cycle all the water runs down the drain
The drain hose outlet must be higher than the 'full' water level in the tub or the water will syphon out until the tub water equals the hose height. If the drain system you are using for the washer is floor level, then you need to install a vertical pipe (1-1/2" minimum) to place the hose end into at the top and it should eject the water through a 90 degree elbow onto the floor at the bottom. There are more elegant solutions, but this will stop the tub from self-draining. Good luck!
Aug 05, 2010 | Kenmore 22422 Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Wahser top loader
possibly cold water should be running into the tub at the same time as the cold to regulate the temp.by only having the hot on, it could possibly have timed out and while still being short of water
Jul 08, 2008 | Whirlpool LSB6200KQ Top Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Water coming from bottom of machine
If this only happens when the machine is filling the hose leading to the top of the tub may be leaking. Before it fills this hose is disconnected from the water supply by a closed solenoid valve. There are two valves which feed into a common hose that comes up to the top of the tub where the water runs into the tub. The leak does not happen after the tub fills because all the water leaks out and no new water runs in. These hoses are usually very small and very inexpensive and held on with clamps. They can usually be replaced by removing a small panel near the hose attachment location.
Nov 30, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
32 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
