Question about Garmin Nuvi 660 GPS Receiver
I use my Garmin Nuvi regularly but this morning when I switched it on it remained silent but showed the map directions (only). How do I get it to give verbal directions again as well as visual directions?
  • Garmin Master
  • 2,130 Answers
All of a sudden my garmin 3790LMT shows "no map data available" how to fix?
Is the SD card containing the map (and update) inside the Garmin device yet ?
Sep 16, 2016 | Garmin Nuvi 3790 LMT GPS
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
How do i reset my garmin nuvi 200w satnav it says no detailed maps found how can i reinstall them
Locate the reset button, located on the back of the device, in the lower left corner. Remove the sticker covering the button, and use a straightened paper clip to depress the tab.
To reinstall maps
Connect your Garmin Nuvi to your computer via USB cable. You can only update the maps through connecting to your computer.
Open the "myGarmin" website and sign in with your Garmin account. Make sure to sign in with the account that you've purchased the map updates on.
heres a link to the site;
http://my.garmin.com/mygarmin/login.htm.
Click the "myMaps" tab on the myGamrin dashboard. This will load a list of all of your purchased map upgrades.
Click the drop-down menu in the "Recent Map Purchases" section. Select your Garmin Nuvi from the list of devices.
Install the Garmin Communicator Plugin when prompted. This is required in order for the Garmin website to transfer the map files to your Gamrin software on your computer.
Download and install Garmin Express. This is the program that allows your computer to interact with your Garmin Nuvi.
Register your device in Garmin Express. If you haven't already registered your device, you'll be prompted to when you start Garmin Express. You'll need to register in order to update the maps.
Click the "Updates" tab in Garmin Express. This will show all of the available updates for your Nuvi, including the new map update you just purchased.
Click the "Show Details" option next to your Map Update. Click the "Install" button that appears. You will need to accept the agreement before the update installs.
Wait for the maps to download and install. Once you agree to the terms, the map update will begin downloading to Garmin Express, and will then be transferred to your Nuvi. This will likely take several minutes to complete.
Close Garmin Express and unplug the Nuvi when the update is complete. The Nuvi will reboot and begin installing the updated software on the device. This may take another couple of minutes.
If you weren't automatically prompted to install Garmin Express, you can download it from
http://software.garmin.com/en-US/express.html.
Jun 06, 2015 | Garmin nuvi 200W GPS
The voice prompting has gone off my sat nav (nuvi 660) it's just silent when we are driving along
I had this problem when I did a map up-date, it didn't complete right. Try re-installing latest map up-date
Mar 02, 2015 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 1350 showing on screen "no map data available"
Shut off the nuvi.
Remove any memory card (if equipped) from your nuvi.
Plug the GPS into your computer via USB cable.
Open the Garmin "drive" icon in "My Computer"
Navigate to the x:/Garmin directory or "folder" (where "x:" is the drive letter assigned to your Garmin). Locate either map files set(s) named: gmapsupp.img or gmapprom.img.
Some units store map files in the hidden x:/.System directory instead. To view the .System folder and contents, you must direct your computer to display both the "system" and "hidden" files.
If you lack large files named either gmapsupp.img or gmapprom.img (about 1 GB or more); your maps are missing from the internal memory of the nuvi and will need to be reloaded.
If you pulled a memory card above, reinsert it and check the directories for the same gmapsupp.img or gmapprom.img files. If they're not present there, the maps should be reloaded.
I hope this helps
Sep 15, 2011 | Garmin nuvi 1350 Car GPS Receiver
I bay n sd card with full europe maps and i put the sd on the garmin 205w but he doesnt work hi dosent show ani maps on the screen
The Nuvi should detect the maps on the SDCARD automatically. A notice appears on the screen to install the maps on your Nuvi. This will take a while to copy the maps from the SDCARD to your unit for installation. After this the maps should be able to function without the SDCARD present.
The Garmin Nuvi needs internal memory for map installation. If there's not much memory left the Map installation might fail. Remaining memory can be checked by connecting the Nuvi to a PC/MAC using an USB cable. It ill appear as an external USB drive. The properties of the USB drive shows remaining memory.
If remaining memory is under 5Gb it might not be enough for MAP install. In this case a master reset to the factory defaults clears memory. This will delete all user data so be sure to store your personal POI's in Mapsource.
A master reset starts by pressing the bottom left corner of the screen for at least 20 seconds while pressing the power button once. A question appears to clear all user data.
Jul 07, 2011 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 205 can't unlock maps
First, check to make sure the map file is there. The file name is gmapprom.img. It's located in the Garmin directory. It should be 1GB in size. To do this you need to connect the Nuvi to a PC with a USB cable.
Next, please tell me what year of map you have on your unit, 2009, 2010, etc.
Them, email me your units internal serial number. Its a 10 digit number (not the number on the outside). The number starts with a "3" and can be found by pressing the tools button, then system and then "about".
Please email me at sharcnet-usa AT sharc DOT NET
- Jim
Mar 25, 2010 | Garmin nuvi 205W GPS Receiver
Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Dec 14, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
62 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
