Question about Casio Exilim EX-Z1200 Digital Camera
Hi, I took some great pictures recently before i realised my kids had removed the SD card, the camera came with a cradle to charge the battery and to download the pictures, this cradle is now broken, is it possible to get these pictures off the camera memory another way. Can i write them to the SD card? If so how? Thanks
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
You can't copy individual files, but you can copy all files from internal memory to an SD card.
  1. Load the card to which you want to copy.
  2. Turn on the camera, enter the Play mode, and press MENU.
  3. Select "Copy" and press right-arrow.
  4. Use up/down-arrows to select "Built in -> Card" and press SET.
For full details, refer to page 203 of the manual.
Posted on Aug 31, 2010
I have a Kodak Easyshare M1063 that I've had for almost 1.5 years, so it's no longer under warranty. I recently had to replace the battery, and since then, I've been having problems with it. Not all the...
Inserting the SD card into a card reader, whether it's a laptop slot or a separate card reader with a USB connection, is actually the best way of downloading pictures. You just have to remember to use the "safely remove hardware" function when you remove it or you risk corrupting the card. This may be what happened. Try going into your camera menu with no card in the camera and if you can, find "reset" to return to factory default settings. If not, remove the battery and this time, press all the buttons on the camera, leave it alone for 20 minutes, insert the card and then the battery. Turn it on. If it works, the next step would be to format the card in the camera. This will erase it so make sure you've downloaded all the pics first.Let me know how this works for you.
Sep 24, 2010 | Kodak EASYSHARE M1063 Digital Camera
My Kodak Easyshare caemra will only hold 3 photos.
You need to switch the camera over to saving pictures directly onto the SD card.
1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If successful please give me the feedback as a rating or recommendation. Thank you
Jan 10, 2010 | Kodak Easyshare 1725043 M893Is Digital...
My camera worked very recently, as I took pictures on a camping trip. However, a few days later after getting back, I've found that it refuses to turn on. If I turn it to either Video or Photo, the light...
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 07, 2010 | Kodak EasyShare CX6200 Digital Camera
Camera will power-up only when connected to DC
This from Sony website:
To ensure the proper operation of the battery, please do as follows after charging the battery.
(1) When charging by connecting the AC adaptor directly to the camera Pleasedisconnect DC IN from the camera after charging is completed. Also, itis recommended to remove the battery from the camera when charging iscompleted as the battery is discharged slightly even if the camera isturned off.
(2) When charging with the supplied USB cradle Ifthe camera is installed in the USB cradle, please leave the power cordconnected to the outlet (when using the power strip, please leave itsswitch to on).If you want to unplug the power cord (or switch off thepower strip) after the battery has been charged using the USB cradle,please remove the camera from the USB cradle. Also, it is recommendedto remove the battery from the camera when charging is completed as thebattery is discharged slightly even if the camera is turned off.
NOTE: When you charge the battery by connecting the AC adaptor directly tothe camera or using the USB cradle, do not leave it with the power corddisconnected from the outlet.
Should it not work, continue with the manual reset procedure below:
  1. Turn off the camera.
  2. Ensure the camera is not connected to an AC power adapter.
  3. Remove the battery from the camera for 15 seconds.
  4. Reinsert the battery.
  5. Turn on the camera.
NOTE: If the issue is not resolved by performing a reset procedure, service may be required .
Oct 09, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Battery Charge error
Hey Lak_69,
One problem I know of is the battery for your camera should be model NP-20 not model NP-40. The NP-20 has 650mAh. I would exchange your new battery for the correct model battery, and see if this works. If this doesn't work I would try cleaning the battery terminals in the camera, and if that doesn't work go ahead and try a new charger.
Sincerely,
Allan
Go Ahead. Use Us.
May 13, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Camera Wont turn On: Is it stuck in USB mode? How do i fix it?
I was able to get past this problem by removing and reinserting the battery. This caused, in effect, a hard reset of the camera, which let me power it up fresh and take pictures again. Of course, it's not exactly reassuring that the problem arose in the first place,
Jimmo
Nov 04, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Pictures mysteriously deleted
Are you sure the pics aren't in a separate folder?
Nov 27, 2006 | Panasonic Lumix DMC-LZ3 Digital Camera
Casio Exilim EX-Z1200 Digital Camera Logo
51 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
