Question about Pentair Minimax NT Heater
The pressure switch light is illuminated and that is the only light that is on. The pool heater was shut off in the spring and worked well then. We put in a brand new filter just before leaving for home, what could of happened to it as it will not operate now. None of the digits for pool spa are illuminated, looks like it is shut down, somehow.
  • 990 Answers
Check to be sure that your gas valves are on at the house or tanks and outside and inside the heater. Then be sure to bleed the gas line. If it has sat for a while the gas could have disapated from the line. To do this just shut the gas off outside the heater and open the line by loosening the flex line or the union at the heater. Open the gas untill you smell gas, then shut the gas down again and tighten the fittings up again. Then give it about ten or twenty min. for the gas to clear, open the valves again and see if this helps. Good luck.
Posted on Aug 31, 2010
The red light on heater won't turn on
This is an indication that the pressure switch is not working. When it completes the circuit thru the pressure switch it send power to the heater. It is the last fail-safe before power goes to the heater.
Bath & Spa Parts Online
Balboa 3 Amp Spa Heater Pressure Switch 2 0 PSI 30408
Aug 09, 2016 | Pool & Spa
If I jump the pressure switch on my Laars Lite pool heater and the pump shuts off, with the high limit switch shut off the heater?
the other safety features will still work as expected. however, by bypassing the pressure switch, the heater will continue to run even if the water system is turned off. since the millivolt system requires no external power to operate, if there is a power outage, the heater will still run causing an EXTREMELY UNSAFE HAZARD. remove the jumper and do without your heater for a week.
Jul 01, 2014 | Jandy Pool & Spa
How do I adjust the pressure switch on my hayward h250 heater
The purpose of the pressure switch is to verify the pool pump is operating properly and water pressure is present in the heating chamber. When water pressure is not present, the heater control system is designed to not allow initiation of flame. The pressure switch is preset at the factory for deck level installations. When the heater is located below the level of the spa or pool, the pressure switch may require an adjustment to compensate for the no-flow static head.
CAUTION: The Hayward Pool Heater is essentially a furnace. A trained technician should be consulted to repair it. DO NOT OPERATE the Hayward Pool Heater without a properly functioning and calibrated water pressure switch. The pressure switch adjustment requires both the pool pump and the heater be operational. As a result, extreme caution should be used during this procedure since sources of energy can not be isolated during the procedure.
The following procedure is recommended to calibrate the pressure switch.
1. The water pressure switch is located behind the front service panel. The pressure switch is typically on the left side, above the burners.
2. Be sure the water filter is clean before making the adjustment.
3. With the pump and heater system switch on, carefully turn the pressure switch adjustment dial clockwise, until a click is heard from the gas valve.
4. Turn the adjustment dial counterclockwise 1/4 turn.
5. Turn the pump off and on several times. The heater should shut off immediately when the pump is shut off. If the heater fails to shut down when the pump is off, repeat the steps above until the pressure switch is properly adjusted.
6. If the adjustment process fails to produce proper results the pressure switch should be replaced.
Jun 22, 2014 | Hayward H Series Pool & Spa Heater...
I have been working to get my heater started since Spring. My pool contractor has been out and cleaned, fixed any issues but now says if I have too high a pressure from my DE filter, the heater will not...
the contractor is correct about having to high pressure in DE filter. it will prevent pressure switch from closing, therefor burners wont fire. However, the pilot issue is a diff problem. you most likely need a new pilot generator
Jul 04, 2011 | Jandy Laars Lite2 Lj 250,000 Btu Heater
We have a Laars Lite 2 which will fire and run for about 5 minutes then shut down. We changed the 135 and 150 limits as we noted a drop from 24 to 14.6 V. It appears to me that the unit is over heating. We...
make sure correct gas pressure if too low it will soot up and overheat sounds like transformer is going should be 24 volts if not pressure switch wont stay on also check the manual bypass by plumbing side if spring is bad water will not go through the heater correctly
Jul 02, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater fires up burns for 8-10 seconds then shuts down then attemps to restart one time then completely shuts down and then the service heater light turns on.
Most Common problem with gas pool heaters is the pressure switch, in order to test it you need to open front access panel and disconnect the pressure switch which the sensor connected to the end of a brass tube, touch the ends together in order to bypass the pressure switch, if it works as normal when doing this then it is just a bad switch, very easy to change. Costs about 30 bucks.
Nov 26, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Pentair Minimax NT Heater Logo
381 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
