Question about HP LaserJet CP3505DN Printer - Color Laser - 22 ppm Mono - 22 ppm Color - 1200 x 600 dpi - PC, Mac
When printing from Tray 1 (using Labels) I occationally get an 41.05 Error (Type Mismatch In Tray 1). I only get this error from Tray 1 and when I use the Labels. I have been using the same printer and label supplier for 3 years and only now I am having this issue. I have checked with the supplier and no changes has been made to the label's quality. I am printing from a Windows 7 x64 operating system using CorelDraw 14. Firmware on Printer is version 03.080.5 The recent changes that have been done on the printer was: Replacement of Pick Up Assembly (Tray 2) Replacement of Fuser Kit. Can you please advice on any possible solutions as we do a large amount of printing with this printer.
    Champion:
  • HP Expert
  • 202 Answers
Replace your laser scanner your problem will be resolved ,Also pls check the paper size before printing..
Posted on Aug 31, 2010
When i try printing with my sharp ar-m205, it automatically reselect bypass tray and gives error "check bypass tray: out of paper or missfeed". But the tray i originally selected is tray 1.
Size mismatch between your print request and the size specifed for the paper in the tray. these trays do not auto-read, you have to tell the copier what size is in the tray
Nov 01, 2013 | Sharp AR-M205 Copier
My new hp 2035n printer give an error when i try to print. the error says: load paper to tray 1
Instructions Things You'll Need:
  • Inkjet printer
  • Labels
  1. 1
    Prepare your printer. Make sure the power is on and the drivers are installed correctly on your computer.
  2. 2
    Wait for printer to stop. Make sure your printer is idle or ready or waiting for paper to be loaded. Don't load labels when your printer is already printing or running an operation.
  3. 3
    Prepare your labels. Make sure they are all facing the same way and are right side up. The label side should be face up. Many labels have an up and a down as well, look for a "this side up" or "load this way" indicator. Or take a look at the print preview before you print and make sure your labels will be fed correctly.
  4. 4
    Find the correct paper tray. Some printers have manual feeds and automatic feeds. Refer to your manual to find out which one you should use for labels. If you are going to use the manual feed, follow the manual's instructions. However, most printers will use the automatic feed, so read on.
  5. 5
    Align the paper guide. This is a moveable piece on the paper tray. There should be markers for the width of your paper. Standard pages are 8.5 inches. Move the marker so your labels will fit.
  6. 6
    Load your labels. Place your labels in the tray so it touches the immoveable side of the paper guide. Slide the paper guide over to touch the other side if it is not already close. Do not bend the labels by pushing in too far.
  7. 7
    Find the paper thickness lever. Try looking under the door that lets you change the cartridges. Or search around on the back or side. Check your manual, too.
  8. 8
    Set your paper thickness level. Usually you'll use the standard size. However, your printer may need to use a thicker setting. Check your manual.
  9. 9
    Change your media type. In your printer settings, find the media type option. You can access settings by clicking properties or settings on the print dialog right before you print. Select "labels."
Oct 02, 2010 | HP P2035N LaserJet Monochrome Printer
How to prink on cardstock on Ricoh Aficio CL2000N
To print on cardstock:
- Load the cardstock paper in the paper tray and make sure the fences are snug but not too tight.
- Press Menu.
- Scroll down to find Paper Input and select it.
- Select Paper Type.
- Select Tray 1.
- Scroll to find "cardstock" on the list and select it.
You'll also have to set your print driver for cardstock or auto select, because if the print driver shows plain paper and the printer shows cardstock paper, you'll get a mismatch error.
Aug 08, 2010 | Ricoh Aficio CL2000N Laser Printer
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
When printing it will not print from tray 2 it wants to print from tray 1 and is asking for labels. Then causing users to have to press the green check twice to change the option to print from tray 2. How...
Ok remove tray 2, and in back its got a little clicking adjustable lever that you need to move so it lines up with letter 8.5 x 11...this worked for me
Nov 27, 2009 | HP LaserJet 4700 Printer
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
No Paper Light wont go out
is this still a current issue?
Jul 22, 2008 | Brother MFC-8860DN Printer
Canon Imageclass MF 6550 - Can't print labels... help!
I have called canon with this problem more than once and they keep telling me that I am using a "paper" that is not supported. I finally gave up and ended up telling them that I am now going to use my cheap HP printer because it can do what it's suppose to.
May 05, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Just changed labels to 99010 and can no longer print
Did you change the label type in the printing preferences?
Apr 07, 2008 | Dymo LabelWriter 400 Thermal Printer
Labels will not auto feed
Have you gone into your print driver and changes the settings there?
I am not sure with your inormation if you have changed the settings on the printer or in the driver.
What it sounds like is happening is that there is a mismatch between the printer and computer.
It may even be set so that it is looking for lables in a bypass tray.
Somewhere there is a mismatch in information as to where the labels are loaded.
Start at the driver properties page and confirm every step in your setup.
Dec 31, 2007 | HP LaserJet 1022n Printer
HP LaserJet CP3505DN Printer - Color Laser - 22 ppm Mono - 22 ppm Color - 1200 x 600 dpi - PC, Mac Logo
188 people viewed this question
Seeker5211
Seeker5211
