Question about Trendware TEW-424UB (0710931502572) 802.11g/b Wireless Adapter
Cannont connect to internet has limited to no connectivity
  • boss429ko Aug 31, 2010
    it just connects and disconnects and repeats and repeats
    all it does is connect then disconnect and repeats over n over
Limited Connection Error
A limited connection on a Windows PC usually means that there is no connection to the internet on that segment. That is if you connect to the printer via a network switch or LAN. Newer printers can act as a DHCP server/router assigning IP addresses to LAN clients. It has no impact on your LAN if you do not want or need a connection to the internet. However if you want to access the internet from this PC I suggest you get a separate router and use that as the DHCP server on your LAN. Connect the PC and the printer to the router and disable the DHCP server on the printer. Also make sure that all devices (PCs and printer) are using the router as the default gateway. Once again if you don't need an internet connection the limited connection shouldn't worry you.
Nov 15, 2013 | Kyocera Mita Office Equipment & Supplies
Why is limited internet connection?
You are facing the limited internet connection only when its secured with the username an password.
Check for it or contact your ISP.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com
May 01, 2013 | Linksys WRT54G-TM Wireless Router
Cannont connect to internet on through my phone
Yeh I got that but which phone and which network
Feb 10, 2011 | Cell Phones
I cannont connect to the internet on my ps3 it keeps saying error 80710092
Hi
Check following steps:
  • If you are connecting your PS3 through a modem have you checked the connection status by turning your modem on and off.
  • You should get a NAT Type 2 if you want a reasonably good connection to the PS Network.
  • Go to ps3 net configuration, write the Ip of the ps3 maybe 192.168.1.xxx, you have to configure it manually not automatic.
  • The resolution is to put in DNS 208.67.222.222
    208.67.220.220 which is OpenDns
Check if this helps, and please do take time to rate my solution
Regards
KreativeGeek
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
When the support assistant tries to contact the internet the notice states it cannont connect? I have a new HP dsesktop pavillion elite.
uninstakll the HP Support Assistant and download it frm HP.com by giving the correct product number and then install it back
Jan 23, 2010 | HP Computers & Internet
My computer says its connect to my wireless network yet I can't access the internet!
Try resetting your router first off. Then repair your connection by right-clicking on the connection. You may have a sketchy router or one that could benefit from a firmware upgrade. I would get into the router's homepage and check the settings for your connection, then make sure your getting IP addresses and DNS addresses from your ISP.
May 31, 2009 | Toshiba Satellite A105 Notebook
Cannot connect to internet via wireless
my phone dont want to connect to intrnet
Jul 31, 2008 | i-mate K-jam Smartphone
Finding the wireless internet
Hi here is a tutorial how to connect up.. support.microsoft.com/kb/314897 One has to ensure that the wifi settings are all the same.. also the Logon & password must be entered as well as any WAP encrytion that maybe used.. It is a good idea to ask the person who administrates the WiFi at the hotel for the setting so you can access and logon to their network.
Aug 04, 2007 | Acer Aspire 3000 Notebook
Trendware TEW-424UB (0710931502572) 802.11g/b Wireless Adapter Logo
123 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
