I have a BOSCH washer/dryer WVTI2840 which keeps showing the error code E06. I have checked the pump and also had a new one fitted! The code still appears but now the machine will not spin on a rinse spin or fabric softner programme. The drum does spin on a normal wash up until the error code show. The washing machine man I called out does not know what is wrong with it???!!!!!! Can you help....please?
  • 2,272 Answers
This error is indicating drain problem.You will have to manually drain the machine. E06 is a draining problem.
When you took the filter out did you check there was nothing jamming the impeller at the back?
Make sure the impeller turns ok. It should ping round in stages.
Also check were it drains to. If under a sink check the pipes there.
If after that its still not draining then its likely to be the pump which is faulty.If you have already replaced the pump then check the connection of pump to the hose.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 31, 2010
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
Bosch washerdryer pump caught fire can it be replaced?
It can be replaced but if you are not electrically trained and there is a major fault, do you want to risk a repair yourself? All Bosch machines have a two year manufacturers cover and even if it is over the two years, Bosch offer a repair plan, basically for a set amount (paid monthly for the year by DD) they will cover the first repair (even though they obviously know there is a fault) and once repaired it will be covered for the rest of the year.Bosch Cust Service No. 0844 892 9002 and ask about the repair plus cover.
Nov 27, 2011 | Bosch Washing Machines
Error codes
If it a washer dryer e06 usually means its not draining, check the filter (bottom, behind plinth). If it is just a washing machine it is possibly a heating fault.
Nov 21, 2011 | Bosch Washing Machines
Bosch washer dryer does not complete cycle and shows error E06 this is even when using the drain and spin programme.
According to my list of error codes for Bosch washer/dryers, 'E06' states 'no water out'
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 15, 2011 | Bosch Washing Machines
BOSCH WASHER DRYER E06 ERROR MESSAGE WILL NOT WORK OR DRAIN WATER ANY IDEAS HOW TO RESET TO FIX PROBLEM.
E 06 means slow or no drain//not a easy do it yourselfer machine//you will need to get to the pump might be plugged//for the do it yourself you can get to the back( but this won't be easy) most techs if they know the machine will take front of that takes pratice//anyhow take rear panal of you will see drain pump in there remove tub to pump hose most likely has some items inside//note some bosch washers have small pump drain hose to get water out before you remove pump hose/if it will drain do that first save alot of mess...........(((( check this first))) note some have round cover at lower bottom put pointy item in hole of cover turn to release ( it will turn hard) some also had cleanout behind that cover/ if so check pump from that location much easier then taking back of.....Hope this helped if it did please vote...if you need more help please ask ...good luck
Feb 03, 2011 | Bosch Washing Machines
Washing machine not draining the water
the weater pump is bad replace....
Apr 13, 2010 | Neff W5340X0 Washer
Bosch washer dryer WVT2850GB error code E06
Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there
Best of luck.
Mar 29, 2010 | Bosch Washing Machines
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Feb 24, 2009 | Neff V4380X0 Front Load Washer / Dryer
Neff V4380X0 Front Load All-in-One Washer... error e06
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
Oct 07, 2007 | Neff V4380X0 Front Load Washer / Dryer
Washing Machines Logo
713 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
