Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover Floormate won't dispense clean solution
My Hoover Floormate won't dispense the clean solution. With the tank off, I pull the handle and the little thing inside the circular fitting goes up and down and is wet from the tank. However, it doesn't make it to the bottom. I have left it running with the handle pulled for 10 minutes to try to get solution through and it just doesn't work. It worked fine for quite some time and then one day solution wouldn't come out. Can you help me please...
  • 2 more comments
  • CindyEG May 27, 2008
    My Floormate has the same problem. When I depress the nozzle directly with the tank off, water comes out. But as soon as I put the tank back on and push the trigger, nothing comes out to clean the floor. It worked fine for two years.
  • adamfau May 30, 2008
    I have the same problem. Yes when I have the reservoir off and I press the valve fluid dispenses but when it is on the vacuum I cant tell. Although when it is on and I pull the dispense trigger I really dont see the spring on the valve move much if at all, but I do see some bubbles come up.
    Thanks for your help
  • Missy08 Jun 08, 2008
    Same problem. Does not dispense the cleaning solution. When I remove the cleaning solution tank and pour water into the "hole" it goes through< however when I put the tank back on I get nothing. When I push in slightly on the bottom of the clean solution tank it pours out. Please help.
  • heathertm Jun 08, 2008
    I have the same issue as reported here - with the tank removed you can press on the diaphram but once assembled the solution won't dispense
    President:
  • 1,673 Answers
The tank sits on what is called a reservior asm, that may have gone bad. Does the water flow out of the tank when you push in the valve at the bottom?
Posted on May 15, 2008
2 Suggested Answers
  • 13 Answers
SOURCE: my hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
Posted on May 25, 2010
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
How to fix clog on hoover floormate fh40010?
I was having the same issue with my NEW just out of box Hoover FH40010. First run on the floor was great then the water/cleaner stopped dispensing!!! I found that when is assembled it out of the box I did not have the handle "plugged-in" properly!! I reattached it to where there is NO gap in the handle when pushed firmly into place and locked in the base. WATER SOLUTION NOW WORKS PERFECTLY!!!
Nov 30, 2012 | Hoover FloorMate Hard Floor Cleaner -...
Hoover floormate h3000 w/spinbrush will not dispense the cleaning solution how can i fix
The hot glue trick will work; but what you probably need to do is gently push down on the black pin from inside the tank. This will lower the solution release mechanism and the solution will dispense. I found this solution on this website and it took 10 seconds and worked well.
Mar 31, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
My hoover floormate will not dispense water
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate h3000 not dispensing cleaning solution after sitting for extended time
check the seat valve on the bottom of the solution tank. should move upward freely. could be stuck if sitting for long period of time
Nov 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Won't dispense cleaning solution
I had this same problem. There is a solution posted elsewhere on this website. Search for Hoover Floormate H3000.
The following solution is the one I tried: Remove the fluid dispensing tank and put a small dab of hot glue on the tip of the blue/greyish "plunger" piece that is located in the middle of the black rubber circle. Let the hot glue dry (this forms an extension to the plunger piece...) and replace the fluid tank.
I did this and my machine is working properly again! Whoever posted this solution was very helpful!
Aug 24, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Jun 14, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floormate
The tank sits on what is called the reservior asm. it is actuated by the control rod inside the handle. With the tank off, watch and see if you can see that rod hitting the reservior asm when you squeeze the trigger. If it is moving up and down on it, then the resorvior asm may be bad. Also check the valve at the bottom of the tank, manually push it in and see if it releases water.
Feb 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate SpinScrub won't dispense cleaning liquid
I had the same problem and was preparing to take it back, the last thing I tried was to 'reseat' the handle -- I removed it then snapped it very firmly back into place. That did it, it's working beautifully now!
Nov 25, 2006 | Hoover H3030 FloorMate SpinScrub 500...
Hoover FloorMATE 3000 won't dispense cleaning solution.
I had the same problem with my Hoover Floormate H3000 and found the solution elsewhere on this website. Try doing a search for Hoover Floormate H3000. The posted solution is basically as follows:
Remove the liquid dispenser tank and set it aside. Look into the cavity of the machine where the tank attaches and find the plastic "plunger" piece (the one on my machine is a blue/grey color) that is surrounded by a black rubber circle. Put a small drop of hot glue on the tip of this plastic "plunger" piece and let it harden. Replace the liquid dispenser tank and try the machine again. My machine dispensed liquid properly after this fix-it.
I really appreciate the poster who provided this simple solution!
Nov 19, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
891 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
