Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
What is gas line routing Gas line broken in tank
What is gas line routing Gas line broken in tank - may have crossed lines during rehook saw will start , but quickly shuts down
    President:
  • 2,220 Answers
Like the following link:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Typical 2375 IPL (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-7/75.2375-Gas-Saw-Type-7.1.59.1.html
All Poulan saws:
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Sep 01, 2010
Mccullugh MCC1840 18" chainsaw. Gas pouring out bottom of saw. How do I get to the gas tank?
The fuel tank is part of the rear handle support body.
The fuel line to the carburetor goes into the top of the tank.
You will also find a return line from the air purge primer bulb. More than likely, one of these lines has broken or cracked. Gain access to some of the lines be removing the recoil assembly.
1) Remove the Air Filter and Filter Cover
(which you have already done)
2) Remove the recoil assembly to gain access to the primer lines.
Feb 14, 2017 | Garden
I have a 2250 Poulan. The fuel lines have been removed. Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out...
Is there a fix for bar oil running out of the saw all the time until the tank is empty?
there is bad oil line repalce it.
Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer\'s suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to?
YES that correct
Dec 29, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
I have an 18" Poulan chain saw, 25th Anniversary
Yes there is.If you can get the broken pieces out of the tank.there should be a filter on one of the broken lines.you will have too buy some gas line 3/16.take some wd-40 and spray the line.this makes it easier to slide through the hole in tank.then loop it around to gas cap hole and reinstall filter.then make sure filter is at bottom of tank and hook back to carb.
Nov 24, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
May 07, 2010 | Poulan ES350 16" Chain Saw
ON a Poulan 220 Pro all of the fuel lines are
Let us start with the bleeder. The 2 hoses that connect to the bleeder are different sizes (Important). If the nipples are the same size connect a hose temporarily to one of them and place the free end in a small container of mix (please be careful with open gasoline and as soon as it is no longer needed put it out of harms way.). Squeeze the bulb if it blows bubbles that is the return side, it gets the large hose and attaches to a fitting on the tank. If it appears nothing happens but when released fuel is drawn into the bleeder it requires a short section of small hose and attaches to one of the carburetor fittings.
A second small hose goes through the tank and connects to the carburetor just like the video including the filter. It feeds the carburetor like it has since before bleeders were installed. I am not certain which carburetor fitting connects to the tank or the primer, please leave them long enough to swap until the saw is running. Logic says the upper most fitting (air bleed) goes to the primer but that is not always true. The Poulan drawing is deceptive it appears the filtered line feeds the bleeder it does not!!!
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but are on different illustrations. They are also beneficial with disassembly/reassembly.
A link to a Poulan "PP220 Gas Saw Type 5 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP220-Gas-Chain-Saw-Type-5/75.PP220-Gas-Chain-Saw-Type-5.1.59.1.html
If your saw is not a Type 5 you can find the correct IPL here:
Poulan.com
The dash number of your serial number is the type.
Lou
May 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel line routing
A typical fuel system and a couple of suggestions follow:
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Replaced gas lines on ryobi 31ccweedeater. my have lines crossed. will not crank.
One fuel line (the one with the fuel filter in the end of it), comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to the top fitting on carburator. That should be the correct fuel line routing. Hope this helped and best wishes.
Aug 28, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
210 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
