Question about Refrigerators
Whirlpool chest freezer when i bought it and had it delivered they dropped it messed up one corner in the back but seemed to be ok was cold didnt use it right away then when i put my food in it never did freeze anything. Well now it wont even get cold at all so wont freeze or get cold.All lights seem to work i hear it running i have tried diffrent temp settings nothing works.
  • 905 Answers
Hindsight being 20/20, you should have refused it when the damage was apparent.
My thoughts
1) would be that when the unit was dropped, a pinhole leak developed, and over time, the refrigerant has leaked out.
2) the evaporator fan was also damaged, and is not turning / cooling the way that it should.
3) the evaporator has a "crease" or bend in the tubing.
The only thing that you can do is to make sure that there is adequate area around the freezer for air to circulate, make sure the coils on the back (if present) are clean. Then make a phone call to the place you bought it from, and have them repair the freezer to fix their original mistake.
Posted on Aug 31, 2010
My whirlpool chest freezer not freezing at all
it not freezing because it cooling system must be damaged,you bought another cooling machine it has mini size and it fixed at the point of older cooling placce.
Mar 22, 2013 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Tip
Refrigerator not gettin cold but freezer is good
ok if you have a refrigerator that leaks from the freezer into the frige all you have to do is put all the food in an ice chest turn it off or better yet unplug it for no less than three hours then clean up the mess you just made on the floor and dont forget the standing water under the veggie drawers plug it back in and turn the thermostat setting to 3 and dont forget get your food back out the ice chest and put it back in frige grab a beer and relax cuz your done ha
on Feb 24, 2010 | Refrigerators
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
Sounds like marbles or ice dropping in refrigerator (not freezer side). Looking into vent in back upper left corner, noise seems to coincide with a flap going up and down. The flap movement is being...
The flap is what open and closes to allow more or less cold air in from the freezer. There could be ice buildup inside the freezer causing this or a mechanical noise of the flap and motor running. See if you can see it from the freezer side of the vent.
May 26, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
One side of freezer has stopped freezing... bottom is not frozen
You have either got a blockage in the system or there is a leak. My bet it is a leak. Seen this many times on the whirlpool.
May 28, 2010 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Can a chest freezer make an ice for 16 hours?
yes sit can make a ice . just increase the temperature thermostat to maximum
Feb 18, 2010 | Bosch 8.72 cu. ft. / 247 liter Chest...
Freezer very cold, no air going into fridge it warm ANY SUGESTION
hi there,
check the blower fan inside evaporator,there is fuse on the back side of your refrigerator for cooling fan,check on this using multi tester if busted replace fuse.
Jul 06, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 | Freezers
Whirlpool WCN 17-8 chest freezer
If you have a older freezer you may have a refrigerant leak somewherein the system. These systems are fairly simple, they eather work or they don't. Most chest freezers do not have a defrost system.
look for an ice pattern on the side walls around the cabinet. if no ice pattern do the sides feel cold? If not were back to refrigerant leak. Appliances do not last 20 years as they use to, anymore your lucky if you get 10 years of use. Washers now start breaking down at 4 or 5 years. The chest freezer is not worth repairing if it's out of warranty. Cheeper to replace, try places like Sears scrach and dent
you can save good money if you don't mind a ding here and there. Hope this helps.
Oct 20, 2008 | Refrigerators
New chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Jul 13, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
