Question about Garmin GPSMAP 178C GPS Receiver
Hi my name is Steven, I bought a used bass boat and it came with the Garmin GPSMAP 178c. My question is how do u set waypoints and use the navigation system so Im not lost on the water? Thanks so much for your help
  • wimpeezee Aug 31, 2010
    Thank you so much!!!!! This is exactly what I needed.. Lost on the water never again!!
  • 905 Answers
Hello Steven,
I can help out with the manual for your 178c Garmin, but as for being lost on the water, that is all on you :) Click on the link to download your manual.
Garmin has, if memory serves, discontinued your 178 in the last few months, accessories are likely still available for it in retail channels. If there is anything that you would like to have, consider getting them now, while still available.
Posted on Aug 31, 2010
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
Please assist me on how to set alarms to my Gps when i get close the destination i am heading to.
to create a proximity alarm for one of your waypoints is a very simple process. First you will want to create a waypoint for you destination. Be sure to name the waypoint something that will remind you of the destination. After this is done go to your main menu by pressing the "menu" button 2 times. Navigate to the "proximity" icon select it by pressing "enter" it will now allow you to create a proximity alarm select the open space and press "enter" it will now give you a list of items you can use select "waypoint" using "enter" and pick the waypoint you created earlier. now all you will have do is select a radius for thee alarm. You can also use the other items to create your proximity alarm such as cites addresses and any other navigation category.
Hope this helps!
Mar 15, 2011 | Garmin GPSMAP 76CSx GPS Receiver
My Garmin GPSMAP 178C screen backlight failed
Backlight problem: Remove the display, remove the light tube from behind the LCD. Buy a led panel from Ebay for around $5 and install it behind the LCD under the drfusing layers. Run the wires out to a 12 VDC source and there you have it.
Jul 13, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
How do i erase tracks on 525S
To edit an existing waypoint:Or MOB
1. From the Home screen, select Information > User Data > Waypoints.
2. Select the waypoint you want to edit.
3. Select Edit Waypoint.
4. Select the waypoint attribute you want to change (Name, Symbol, Depth, Water Temp,
Comment, or Position).
To delete a waypoint or an MOB:
1. From the Navigation chart, use the map pointer ( ) to highlight the waypoint or the MOB
on the Navigation chart.
OR
2. Select the waypoint or the MOB you want to delete.
3. Select Review > Delete (The Review button is only shown when more than one waypoint
is in the vicinity.)
Sep 24, 2009 | Garmin Gpsmap 525s Dual Frequency Combo...
Garmin 178C Boots up then shuts off
Check the pins at the connector on the back of your unit. Make sure one of them is not bent or broken off. One of the pins on mine is missing about 1/16" of the tip. My boat repair shop says it's the power lead, but Garmin wants $200 for a generic repair.
Oct 18, 2008 | Garmin GPSMAP 178C GPS Receiver
GPSMAP 60CSx
You can't turn the navigation back on with this method. You must once again highlight the waypoint you want to navigate to in your Fine>Waypoints screen and then press the "Go to" highlighted button on the screen.
Jun 25, 2008 | Garmin GPSMAP 60CS GPS Receiver
GPS wont boot up
Use with caution: This will delete your user data on the unit.
Try a reset:
  • Hold QUIT pressed when turning unit ON (will delete waypoints, routes and tracklogs)
(This worked for me when I had a similar problem.)
You could try a master reset;
  • Hold Zoom-OUT + QUIT + NAV and power ON. Hold keys for 10-12 seconds.
  • You lose all almanac and temperature compensation tables (it reconstructs itself but takes time - several hours)
  • Be patient - it will take HOURS for the unit to recover
Fair warning: I have not personally tried the master reset.
Sep 28, 2007 | Garmin GPSMAP 276C GPS Receiver
Garmin GPSMAP 178C GPS Receiver Logo
129 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
