Question about Whirlpool Washing Machines
Hi i have bought ABM551 5.5Kg washing machine and i am unable to use it need the demo
SOURCE: ge profile front load washing machine demo mode
GE Profile washer WPDH8800 stuck in demo mode: unplug, plug right back in, within 30 seconds, open the door and press start/pause 5 times in quick succession. Here's the link that took a day to find: http://www.geservicenet.com/cc/trngprog/ProfileHAWasher_V4.pdf
Posted on Jan 08, 2011
  • 6277 Answers
SOURCE: beko washing machine a+a class
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 10, 2011
  • 45 Answers
SOURCE: Aftron Washing Machine draining power
check and see that the entire drain line is free from any obstructions, if you have lowered the hose and still not draining entirely, its a sure sign of obstruction somewhere in the drain line or even the drain pump.
Posted on Jan 27, 2008
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Posted on Apr 10, 2009
  • 9 Answers
SOURCE: how to change the belt on 5kg hoover washing
you have to re alliegn tha motor
Posted on Jul 19, 2009
Hi, just bought a Whirpool front load model wfw75hefw. Looks like it is stuck on demo mode. Anybody knows how to turn off the demo mode. The dryer was on demo mode and I was able to turn off the demo mode,...
1. Press SETTINGS/CLOCK until "DEMO MODE" is displayed.
2. The current setting will be displayed.
3. Press the "1" keypad to adjust the setting.
4. Press START or CANCEL to exit and display the time of day.
This should put you in normal operating mode.
Apr 08, 2018 | Washing Machines
Hi just bought a washing machine Whirlpool FSCR80421 and is stucked in Demo Mode. How can i exit?
Look for a reset button or contact whirlpool for the procedure to restore machine to factory defaults.
Sep 11, 2017 | Whirlpool Washing Machines
Whirlpool wwdc 9940 , it's one in the 6th sense range. I believe my washing machine is stuck in demo mode and I cannot get it back to being usable. Help!! I have so much washing to do!
I don't believe there is a demo mode in a washing machine. You would either do a wash or not do a wash. The internet seems to know nothing about it either. Contact the dealer.
You do have the water switched on?
If you have used the machine normally before, you have a fault and need to call a repair man.
Aug 16, 2015 | Washing Machines
Got a ex demo siemens IQ 700. How to unlock the demo mode?
Best is ask store that you bought washer for help you or go online and contact manufacture for support
Dec 09, 2013 | Washing Machines
The digital screen is stating H20
This is what I have been told- by a reputable company (!)
If it is not in DEMO mode it means that there is no water being supplied to the machine. If it is in DEMO mode cancel it by pressing and holding the start/cancel button then press again to cancel the drain and the machine should display 'ON' as usual.
Good luck,
John C
Apr 04, 2011 | Hotpoint Aquarius WD640 Front Load...
Bought demo didn't come with installation disk please help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 27, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Ge profile front load washing machine demo mode
Open the door
Good washing!!
Jan 04, 2009 | Zanussi IZ141W Front Load Washer
Hotpoint Ultima dishwasher dwf70
Press and hold the start and the on/off buttons together. It should come out of demo mode.
Aug 25, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
