Question about LaserJet 3052 All-In-One Printer
Long time scanner warming up display & then scanner error
    Problem Solver:
Open the scanner unit clean all the glasses and mirrors with lint free cloth, that they are dust free and get shinning. the problem is solved.
Posted on Nov 20, 2010
Fujitsu fi-6140 Scanner: Error 8 (help?)
Hello Connor,
Error 8 could be displayed due to:
1. Faulty cable connecting Panel PCA & Control PCA. Check the cables, it might have been pinched somewhere or may be defective. You may cross check by replacing the same with another scanner.
2. Faulty Panel PCA. You may cross check by replacing the same with another scanner.
3. Faulty Control PCA. You may cross check by replacing the same with another scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jan 09, 2014 | Fujitsu fi-4120C Path-Through Scanner
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Hello, The scanner & photocopier were not working and the screen was just stuck on the "scanner bulb warming up". Then, after days of trouble shooting, it finally began making a noise,...
From what you described it sounds like you need to get the "scanner assembly" replaced.
The bulb is probably bad and won't come on to full power.
Not knowing what kind of printer you have, probably won't change the fix. If you can look at the event log you may be able to see an error code which could make it a definite scanner assembly replacement.
If you want to throw money at this unknown printer, get a tech to look at it and give you an estimate.
Jan 17, 2011 | Office Equipment & Supplies
MY CANON MP510 KEEPS SHOWING ME A ERROR 5010 WHEN I PRESS SCAN CANNON PIXMA MP510
The scanner unit cannot detect the home
position, or the scanner unit warming-up is not
done properly at power-on.
On the LCD, "SCANNER ERROR" is
displayed.
Mar 27, 2010 | Office Equipment & Supplies
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Sep 23, 2009 | HP LaserJet 3030 All-In-One Printer
Scanner error 12
uninstall the software of scanner and reinstall it
check your cables for loose contacts
Jul 04, 2009 | HP LaserJet M1005 Printer
Aficio 551 - error code SC124
Definition- [B]
No encoder signal from the scanner motor
-Possible cause-
• Scanner motor connector defective
• Scanner motor defective
• MCU defective
• Scanner wire, timing belt, pulley out of position
• PSU defective
The screws of the pulley usually are cut that moves the scanner this causes that the car is crossed and that the sensor does not detect the home position. check and corect this defect.
Mar 03, 2009 | Ricoh Aficio 450 Copier
"Warming up Please wait" error
Suspect the toner heating element (fuser) may be malfunctioning. Dell may be able to walk you through a "hard reset" that involves opening the front door, turning on an off the printer with certain buttons held down, etc.
Jan 14, 2008 | Dell 1600n All-In-One Laser Printer
Coppier Problem
The trouble is that the scanner assembly can't find its "home" station. Here is the most common solution. There is a reflective white stipe under the scanner glass that the scanner looks for. If the stripe is dirty, or if the scanner mirrors are dirty, the scanner won't sense its location, and cause a "scanner error". A qualified technician should be able to clean the assembly. The other option is to replace the scanner assembly. I hope this helps.
Feb 27, 2007 | HP LaserJet 3330MFP All-In-One Printer
LaserJet 3052 All-In-One Printer Logo
Top Laser Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
CheckitRight
CheckitRight
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
