Question about Frigidaire GLEQ2152ES Electric Dryer
My dryer has stopped heating and has started to lightly squeak. What's wrong?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: At the start of the
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Aug 05, 2011
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
Kenmore elite quitepak 9 dryer is squeaking
What kind of vent piping are you using? The wrong vent pipe can cause the wheel over the heat element to overheat and squeak. It is recommended that rigid metal vent pipe is used now a days.
Nov 24, 2012 | Dryers
Squeak dryer used to warm up and stop now it's the devil
Hello auntrhodie - If the unit turns on but it is not producing any heat please have a professional diagnose the heating element and the blower assembly. Either part could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 02, 2012 | Frigidaire FEX831CS Top Load Stacked...
Sdg515daww maytag legacy series gas dryer will not put out any heat until the dryer has been on for about an hour or an hour and a half...have cleaned external vent tubing and vacuumed (as far as vacuum...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Dryers
At the start of the drying cycle the dryer would squeak for a few minutes as it heated up the squeaking would stop ;now the dryer will not turn on, only hums whn the start button is pushed..HELP!!
heatman101
Jul 30, 2011 | Dryers
Dryer not heating and squeaking
heatman101
Jan 14, 2011 | Kenmore 600 6965 Electric Dryer
My dryer squeaks horrible while running. It has broken 2 belts in 3 weeks. What is wrong?
Jockey pulleys are faulty you will find squeak alters as drier heats....
Sep 29, 2009 | Dryers
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Squeaks from drum area during operation
We have a Bosch Nexxt dryer and it, too, squeaks during operation. We have not been able to find a permanent solution for this problem although we've had the repairman come out 3 times now. We have however found a temporary solution that lasts for about a week. We spray Static Guard (in an aerosol can) in the inside lining of the dryer... kind of in the lip of the front. (You shuld be able to feel it if you put your hand right inside the door.) We've just been spraying the static guard all the way around that area and the squeaking stops! Hope this works for y'all. May not be permanent but at least it stops the annoying sqeaking!
Oct 25, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
66 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
