Question about Craftsman Garden
My lawn edger craftsman 3.5. h.p. will start ,THEN SHUT DOWN RIGHT AWAY.why?
    President:
  • Craftsman Master
  • 1,545 Answers
Fuel delivery problem most likely. Fuel is getting INTO the carburetor but that fuel is NOT making it into the engine probably because...the Main Jet may be clogged. This is the brass bolt that holds the bottom bowl onto the carburetor. It has an exterior washer (dont lose it). Remove this brass bolt and clean all the tiny holes in the bottom and sides of it. Clean the bowl up nice (dont forget the main body gasket too) and replace it all....now the gas WILL make it to the engine.
Posted on Sep 02, 2010
Why does my new Craftsman 4 cycle Trimmer's head turn counter clockwise
Curved shaft trimmers turn clockwise.. straight shaft trimmers turn Counter Clockwise. Also the Bump head is reverse threaded because of the engine rotation.
When using this trimmer , Angle the right side of the string line down so the grass gets thrown in front of you not at your legs.
May 30, 2015 | Craftsman Garden
How do you get air bubbles out
If the bubbles will not go away you may have a broken fuel line inside your tank. Some bubbles are ok.
Jul 28, 2014 | Craftsman Weed Wacker Lawn Edgers
Why wont my craftsman 25cc start
99% of the time its a carb or fuel problem. Always run premium fuel and store the machine in a cool place less than 100 F
Might can put a drop or two of fuel down the carb and revive.
Jul 18, 2014 | Craftsman 25cc Gas Line Trimmer
How do i change from trimmer to edger?
I know that on Black and Decker there is a button down on the head near where the shaft enters that when depressed will allow the operator to rotate the head to a new position 90 degrees away from start position. On my Craftsman, the joint between the power unit and the driven unit there is a little pushbutton that allows the head to be oriented in four different directions.
Jul 08, 2011 | Homelite Consumer Products 4.0 Amp, 13 In....
Cannot find manual for Craftsman Lawn Edger Model No.358.757551
I could not find any equipment by Craftsman under the model number given. Here is the manual to a "typical" Craftsman gas edger.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L9060260.pdf
Jun 08, 2011 | Craftsman Garden
I have a Model 29270 REV B00 Craftsman 4 cycle mini-tiller. Can't find a spark plug or air filter. Appreciate some direction.
Craftsman part numbers will help on this search. Typically 3 digits separated by a '.' such as 345.45687
If you can find these, please re-post the question. :)
Sep 25, 2010 | Craftsman Gas Mini - Tiller/Edger
My craftsman weedeater just shut off while I was using it. It had ran for about 20 min with no problems? Anythoughts...and yes it has fuel
Check 3 things: 1-are you getting spark/ is the plug good
2. is the carb getting fuel/ is carb "jammed" or is there a line pinched or broken 3. Do you have compression These are most common things to check that usualy resolve the prob.
Jul 10, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
May 20, 2009 | Garden
Start, but don't stay running
ok starts how long?
and is this after pumping the primer? also choke postion make sure you change it after it starts right away and make sure look under air filter to see if choke is closing when operating choke.
Apr 16, 2009 | Craftsman Garden
Garden Logo
237 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
