Question about Electrolux Guardian Bagged Canister Vacuum
Lux legacy is making a very loud noise? Still works but I'm concerned it might be harming motor?
  • pinchees Aug 31, 2010
    Thank you. Will get this into the "shop"
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue can be due to many reasons: probably the bearing is out or the motor itself has gone bad and/or the impeller is bad. To check what is causing this issue you’ll have to take it apart and then check start with checking the edges of the impeller, if these edges are broken then it’ll cause a loud sound. If this is fine then check the bearings as they might have failed causing this issue, also check the fan as that might be loose. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 31, 2010
  • Roger Potts Sep 23, 2010
    Loud noises often come from the power nozzle section of an Electrolux (now Aerus) due to small heavy items being picked up and not making it up the hose. A loose or broken belt will result in loud thumping and burning rubber smell.
    Unless someone dropped something down the bag well when there was no bag, or a bag broken, there should be nothing in the main machine that would cause a loud thumping. Fans are metal, attached directly to the motor, and only in situations in first sentence of this paragraph will anything get into the fan and chip or break the "blades".
    This is a pretty recent, still on the market vacuum, and may very well still be under warranty. It has a 10 year warranty on the canister components, including motor and fan assembly, against defects in manufacture and workmanship. The accessories, including the power nozzle, have a 5 year warranty on them. See owner's manual for more information about the warranty.
My bissellpro heat is making a loud noise as I clean carpets. What can I do?
If the belts are good and not slipping, the noise could be a bearing issue.
Oct 02, 2017 | Vacuums
What is the difference between the electrolux lux 7000 and the electrolux lux legacy
different motor,the legacy does not have a filter,but the same bag...one is made of a light metal [legacy] the other a polycarbonate plastic. Chris
Jun 24, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Our dyson vaccum is making a loud noise when we vaccum. (other than the normal loud noise) it is a dyson 23 plus..
Sorry to hear you're having trouble with your DC23 Plus. You might find it helpful to wash the pre-motor filter, and to check the cleaner for blockages. You can find a step-by-step guide showing how to do this in the Support section of our website:
http://www.dyson.com/support/help.asp?article=1276&product=DC23-PLUS
You should find that this resolves the issue. However, if you've tried this and you're still concerned about the noise, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON. We can run through some troubleshooting over the phone, and provide the assistance you need.
Kind regards,
Jack
Dyson Customer Service
Jul 25, 2011 | Dyson Vacuums
Lux legacy canister vacuum - the top light on the canister went on. No power to the bottom of the roller. What does that light mean. Looks like a plug
The "plug" light simply tells you the machine is plugged in and receiving power.
I'm not sure what you mean by "no power to the bottom of the roller". If the power nozzle motor isn't working, make sure nothing is wrapped around the brush, remove if there is, and press the reset switch.
If the power nozzle motor is running, but the brush isn't turning, then the belt must have broken, and needs to be replaced.
Considering your machine may still be under warranty, I suggest taking it to a local Aerus dealer and having it replaced.
You can find the store nearest you using the below site:
http://www.aerushome.com/shop/
Apr 27, 2010 | Electrolux Guardian Bagged Canister Vacuum
Vacuum cleaner Lux model motor fails to start
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
Mar 23, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux legacy
Actually the problem is inside of the canister itself. You need to change a part called the control valve. Occaisonally when fine particles get inside of the valve it damages the inside of the valve, sending a false reading to the main motor, causing it to shut off. This is a relatively quick and easy repair and should be recieved on a same day basis.
Oct 20, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux Legacy shuting off by itself
i would say it is over heating but some times you cant tell because electrolux have a sensor so when the get hot the turn off till they gool down soo if you really like the vacuum get it look at by a vacuum repair man.
hope this helps
May 10, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Electrolux Guardian Bagged Canister Vacuum Logo
151 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
