Question about HP Compaq nx6310 Notebook
Laptop not booting
I have try repaired or format the laptop but every time HDD not detected & give the error to esc the setup & laptop reboot again. Please help me to find out that tipe of problem.
  • 1 more comment
  • RedtopHat May 09, 2008
    All the parameter proper set but still problem not resolve...
  • Anonymous May 14, 2008
    detect hdd format it but need a intel matrix storage manager driver
  • 4 Answers
What has created the need for a format/reinstall?
My guess:
Bad HDD.
Posted on May 09, 2008
    Genius:
  • 1,224 Answers
System bios is not set on auto find of hdd or you might have to enter parameters yourself for hdd
or just corrupted files which requires a compaq driver setup disk some compaq are like that
can boot off sys. disk
  • Christophe Thompson
    Christophe Thompson May 09, 2008
    if in process of the setup of your O.s sys. and gives the error you might have a virus called kb4......... the numbers i cant remember i got hit by the recycling boot virus << is what i call it
    you need your boot up disk and do a full format a full fdisk parameter setup
    fdisk the old parameters and delete them and make new fdisk parameters then let the boot disk of O.s sys. handle a complete and full format not a quick format and do a ntsf system setup
    fdisk is what sets up the dos prompt
Formatted HDD wont install windows 7 ULT disc
It may be that your BIOS is not setup to boot from CD before HDD. To get to the BIOS, look for the message for getting into the BIOS on the first screen after rebooting. There are many versions of the BIOS depending on the computer, but usually its F1, esc, del, F2, F3. It should say which to push on the first screen after rebooting. Look in the BIOS fot boot order, then put CD drive as the first boot order. Then save by either hitting F10, or pressing esc. This will make it so it looks for a boot.ini on the CD before firing up the HDD. Some CDs/DVD's will boot on their own, but usually it will say 'Press any key to boot from CD'. Press that and go from there. I would choose the option to format the drive before it installs, since the way you did it might not of erased it all the way. (Usually a clean formatted HDD will say 'Missing Operating System', not boomgr missing). Try that first then let me know if this worked for you. Also, if you are using an windows 7 upgrade disk, it will not work. Has to be the complete operating system disk for a clean install.
May 30, 2013 | Dell Latitude E6510 Laptop
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
It is stuck on the " acer empowering people" screen it gives me options at the bottom to press F2 for setup and F12 to change boot order but when i press either of these nothing happens ive tried...
try restarting and push esc a few times should go to boot option screen ,,set it to boot from hdd,,or jus put ur cd that came with or windows disk and repair,,,,,check acer website also
Nov 03, 2010 | Computers & Internet
I have a HP Pavilion dv2722tx,and last time i buy that time,the technician help me format my laptop to window xp not original one,and then after 1 year my laptop window currupted, and i want format window...
Hey,
What u need to do first is go to bios - check for the tab tool or
Diagnostics - check wethere u can run a hard drive self test check for the results , if u get error 1-07 or 1-08 or any error then the hard drive has gone bad, if it gives u error cannot find hard drive then u need to reseat the hard drive.
The hard drive compartment is at the bottom of the Notebook , a compartment with 3 circular disks placed one over the other.
After u have removed the cover , u will find a black stirp which u can pull and the hdd will come out with it put it back again and then check in bios if it is getting detected under tools or Diagnostics, if yes then put the cd for xp in and keep tapping the ESC key on the keyboard ,it will give u boot option choose CD DVD Drive and press enter .
Reformating starts.
( If hard drive is not getting detected even after reseating then hardware issue with laptop needs repaire .. harddrive connectors have gone bad.)
Mar 31, 2010 | Dell Latitude D600 Notebook
Good day i have tried to install Win XP on my acer aspire laptop after formatting the HDD on another machine but i cant, the acer did not recognise the HDD. what do i do
Do you have an Xp disk? This is the only way I know of to install Windows Xp without encountering any problems.
You will need the disk; also you need to make sure that the boot options see that you want it to boot from your cd drive. When you start your computer up, get to this screen by hitting the key to enter setup options shortly after hitting the power button. It's where you change your BIOS and other stuff.
This is where you can make sure it recognizes your new HDD and change your boot option to #1-boot from cd drive.
Reply to this if you need more info.
Hope this helps.
Dec 15, 2009 | Acer Aspire 3000 Notebook
New build pc no boot... black screen
Try to remove the battery from the MB, and next time you try to install WIN XP, when you are asked how to format your drive, chose quick NTFS formatting; disable floppy drive in BIOS, because it might try to boot from it (and I suppose you don't have one), and in boot sequence (BOOT DEVICE PRIORITY) set cd-dvd as first, and HDD as second, and turn off any other device as bootable
Nov 17, 2009 | ASUS M2N-MX Motherboard
IBM server dc can't boot due to system32\drivers\pci.sys missing
You mention on boot that the server shows a logical drive of 158GB, which obviously means the server is detecting the drives ok.
Quite often Windows doesn't have the correct drivers to support systems using RAID controllers such as IBM ServerRaid, so this is probably why the setup CD states "No HDD detected, press F3 to reboot". When the Windows Setup CD Boots, it should at some point (on the blue screen) at the bottom of the screen state something like "Press F6 to load additional drivers". If you can get the correct drivers from IBM website, and load them by pressing F6, Windows should be able to see the drives ok. Hopefully it will then be able to successfully repair the error.
May 23, 2009 | IBM eServer xSeries? 206m
IBM r52 thinkpad laptop hdd compatibility issue
Download Hiren CD .. format the hDD and install the OS Freashly
Mar 31, 2009 | IBM ThinkPad R52 Notebook
Packard Bell Easynote M5255 - Will not boot up
option f2, go into bios setup and see if the hard drive is listed or detected. Auto detect hard drive save and exit. System will reboot if the same error occurs then the hard drive master boot record is probably corrupt or the hard drive has totally failed.
Apr 19, 2008 | Computers & Internet
HP Compaq nx6310 Notebook Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
