Question about Sharp MX-2300N Color Copier
I have a sharp mx2300 color copier with the trouble code F2-64. Before the code appeared, my copies came out darken with the black toner.
  • 61 Answers
That code is Toner supply adnormality error, there is a pipe in the back of the machine that gets clogged sometimes. Or the gear that drives the tone is broke. Either problem would be better handled by a trained tech. There is no easy fix.
Posted on Aug 31, 2010
Mx2300 write code f2-70 after replacing the black cartridge
F2-70 is indicating an improper toner cartridge K.
If you have just changed the black toner cartridge & the error appeared then the new toner is at fault.
Replace the toner cartridge with another cartridge, turn the machine off & back on & the machine should reset.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Mx-2300n Copier Color Mx2300n...
Why is my Sharp MX-M263N copier creating black lines on documents?
Check out my video for helping this issue. I'm not sure if it pertains to your model, but it may be of use to you.
How To Remove Lines from copies prints on Sharp copier
Jul 30, 2014 | Sharp MX-M623N Black Toner Cartridge...
Product key PS3 Expansion Kit mx2300
The SHARP corporation will be happy to sell you one. Otherwise, what you are asking for is piracy.
Dec 09, 2013 | Sharp Mx-2300n Copier Color Mx2300n...
There's a black line on copies of SHARP AR-5316E
Cartridge(s) may be putting out too much toner or scratched
Aug 27, 2012 | Sharp AR-5316 Advanced Digital Imager...
I have a Sharp AR M-165. If I try to do more than 20-30 continuous copies or prints I get a darkening of the top 40mm of the copied page which gets gradually darker and darker the more pages that are...
are u using a compatible toner or branded.this problem might be occurring due to toner .try to change the toner and developer .both at the same time because if u change the toner then the toner in developer module will get mixed with new one and u will have a problem
May 24, 2011 | Sharp Office Equipment & Supplies
The copies comes out totally black
H2 00 Thermistor open, your fusing unit needs to be serviced (cleaned or replaced)
The black copiers can be a number of things a few things to check and what the remedy could be;
  1. Open the right door, if you notice a lot of toner/developer spilt then you could be having a charge corona short (built onto the drum unit) clean corona
  2. Open the right door, if you drum (green or blue cylinder (depending on brand of drum) under your fuser) is coated with toner (should be all green/blue) then you could be having a drum short, replace drum unit for this.
  3. Open the right door and on the door towards the bottom is a metal unit with a white guide built on it (transfer corona) if there is a lot of toner/developer in it (looks dirty) then this needs to be cleaned or re-built.
  4. You also could be having a board issue causing the black copies.
Mar 26, 2009 | Sharp Office Equipment & Supplies
Fax Recive Error on sharp MX2300-N "receive impossible"
Communication report codes
46 NO RESPONSE The FAX signal from the remote party is not detected within T1 time. <Send/Polling>
Feb 04, 2009 | Sharp MX-2300N Color Copier
Stopped working
try to see if there is a number appearing after u, maybe its u2-40 which is a toner problem since you run it continously. You can check it by pressing the copy button(green) and the sub code will appear. try to replace the toner cartridge and reset the copier by turning it off and on again, hope it helps
Nov 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp MX-2300N Color Copier Logo
696 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
