Question about Microsoft Xbox 360 Console
When i try to turn my xbox on, the power button turns red with 3 out of the 4 quadrants, what is wrong with it?
  • 4,102 Answers
Hi, you have got the red ring of death problem, if you google the following you will see exactly what im talking about:
how to fix rrod free guide
then hit search then that will list loads of sites that offer a guide on fixing this problem.
now the problem itself is to do with the fact that either the gpu chip or the cpu chip on the main circuit board has over heated, now if you have any warranty left i would take it back and get an exchange.
when microsoft made the xbox they used some cheap lead free solder and it is very brittle, and over time the solder cracks and you get the red ring of death, now their is an xclamp fix you can have done to solve the problem, but it wont be a long term fix, it may last a week it may last 3 or 4 months but in the end its going to fail again and be un-repairable,
i have done many xclamp fixes on 100s of xboxes and 8 out of 10 of the times it solves the problem and gets them working again, their is also a trick you can do using a towel but this is only a very short term fix, what you need to get done if you want it working again is get it taken apart and have the old heat sink paste removed and new paste put on the cpu and gpu chip then the heat sink needs replacing with the xclamp fix this will then get your xbox working.
i buy damaged xboxes all the time that have your problem and they are fixable but the fix may only work for a week or two so you need to bare this in mind if your going to have the work done, failing that you would need to get a new xbox.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Aug 31, 2010
Xbox 360 3 of the 4 quadrants on the console flash red when turned on
Yeah thats the red rings of death, usually. I used to have a 360 and when that happened to mine I just pushed the big button and it was fine ever since. But if that doesn't work for you, make sure all connections are properly connected or if it overheated wrap a damp towel around it. If none of these things work, get it fixed.
Dec 04, 2010 | Microsoft Xbox 360 Console
Red rings on the xbox 360 wont connect to live wont let me recover gamertag
The red rings are a fatal Xbox 360 error. There is no way to solve this problem except by having a qualified professional perform a reflow to the problem Chip. This can usually be determined based on the number of quadrants lit.
  • 1 Red Quadrant is usually System Error. A "E##" error code will be displayed on the screen. Most common is E74.
  • 2 Red Quadrants indicates the console is overheating.
  • 3 Red Quadrants indicates hardware failure. A secondary error code can be acquired by pressing and holding the sync button then while continuing to hold the sync button repeatedly pressing the eject button and noting the number of red quadrants that becomes lit.
  • 4 Red Quadrants indicates that either no A/V (Audio / Video ) Connection is available.
Good Luck! Let me know if you have any further questions. If you tell me which number of quadrants or the error code I can point you in the right direction.
Jun 04, 2010 | Microsoft Xbox 360 Console
I cant get the xbox to work from the controllers, when i press the "x" button on the controller it just keeps flashing and doesn't allow me to link up with the console
The "x" button is the xbox guide button that is in the center of your controller.
1. First, turn on your console by pressing the power button on the console itself.
2. Next, press the xbox guide button that's on your controller. (The button that lights up and flashes when you press it).
3. On the front of your console, just to the right of the memory card B slot & just below the right corner of the DVD tray, there is a small, round connect button.
4. With the both the console & the controller on,(lights flashing) press and release the connect button on the console first.
5. Then on the controller, press the connect button (green arrow, circled in red) that's between the Left Bumper button (LB) and the charging port (blue arrow).
6.The lights on the controller and on the console should continue to go in a circle and stop.
7. The upper left quadrant is controller # 1, the upper right quadrant is controller # 2, bottom left is # 3, and the bottom right is # 4.
8. Once the controller connects the the console,you're all set. Then the next time you go to turn it on, just press the xbox guide button on the controller and it will turn the power on to the console for you.
9. If you ever take your controller and use it on another 360 console, you have to go through the same connection steps as you just did. And then again, when you get back to your console
Hope this helps! Happy gaming!
Dec 17, 2009 | Microsoft Xbox 360 Console
3 red rings
Over on another forum they listed how to decipher what your Xbox360 is trying to tell you when you get the three rings of light. There is a code that will flash if you hold down the "Synch" button (White button near the memory slot) and press the DVD Eject button. You will notice the quadrant of lights illuminate and each time you press the eject button you will get a different code.
It breaks down to this:
All four lights illuminate = 0
One Light = 1
Two Lights = 2
Three Lights = 3
Example:
Turn on your "dead" xbox. Wait for the 3 red lights. Once you get them hold the "Synch" button and the eject button down simultaniously. All four lights flash. (0) Press the eject button again and only one light (1) press again and all four light up (0) press again and two lights (2). Error code is 0102. compare this code to the table below to find out what is wrong with your X360. Is it overheating? Power Cord? Hardware?
The Code I got is 0102 which means the computer does not know the problem as it is not hardware or heating or anything like that. Could be dust, loose solder or static! I use a can of compressed air and my X360 IS BACK!!!!!! I do not know for how long but I played last night for several hours and had not one Hiccup. This after a whole week of the dreaded RINGS OF DEATH!!
Dec 02, 2009 | Microsoft Xbox 360 Console
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
Setting up a 360 wireless controller
Turn Your Console and Controller On The Xbox® Guide button in the center of your controller puts the Xbox 360® experience at your fingertips. Press and hold the Xbox Guide button to turn your console on.
To turn on your console only, press the power button on your console. To turn on your controller only, press the Start button on your controller.
Once on, pressing the Xbox Guide button gives you immediate access to the Xbox Guide. To turn off your console, press and hold the Xbox Guide button for three seconds and then confirm your selection.
Turn Your Console and Controller Off To turn your console and controller off, press and hold the Xbox Guide button on your controller for three seconds. Then select whether you want to turn off just your controller or both your controller and your console. (Selecting the console will turn off both the console and all connected controllers.)
To turn off one controller when multiple wireless controllers are connected, press and hold for three seconds the Xbox Guide button of the controller you want to turn off, then select Turn Off Controller.
To turn off your console only, press the power button on your console
When you connect a controller to your console, it is assigned a specific quadrant, which glows green to indicate the controller's number and position. Each subsequent controller connected to the console (up to four) is assigned an additional quadrant.
If system problems should arise, the Ring of Light on the console will flash combinations of red.
I hope this solved your problem.
Happy Gaming!
Oct 17, 2008 | Microsoft Xbox 360 Wireless Controller
Xbox 360 two red rings
I suggest you to try DIY Guide that wil explain solving the two red lights along with some other common problems of Xbox like Disc Read Error, No Video Problem and most famous RROD. Even a novice can solve the problem with the help of step by step process given at the guide. I think it's worth trying. If you try this method, you won't have to wait for 3-4 weeks and you can enjoy your gaming experience within 2 hours, once you try this guide.
Oct 13, 2008 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
Xbox360
Are all four quadrants blinking red around the power button? This indicates that your Audio/Video cable is not plugged into the 360. Unplug it and plug it back in, or make sure it is securely plugged in.
Any other problems, contact Microsoft and 1-800-4-MY-XBOX and they will promptly fix it if it is still under warranty.
Jan 28, 2008 | Microsoft Xbox 360 Console
Xbox 360 red lights
2 red lights flashing is'nt too bad of a deal. just reposition your xbox 360 to a place where more airflow can get to it. plus, dont have anything that gives off heat near the xbox 360, thats vary important to give it room for cool air. it worked for me
Nov 15, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
