Question about Amana Heating & Cooling
I have an Amana home air conditioner and I need help in locating the reset button
  • 32 Answers
There is no reset button on the ac maybe the tstat
Posted on Sep 01, 2010
How do i fix E1 error
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2 Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditioner. Move to the next step if the LCD continues to display the E1 error code.
  • 3 Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4 Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor responsible for detecting room temperature may be defective.
  • Jun 10, 2014 | Amana Acd12ke-e Window Air Conditioner
    How do I reset the amana PTH093B35AM to default settings?
    you must read your instr. manual how to reset to default setting
    go to www. fitness.manualsonline.com
    God bless you
    Oct 08, 2012 | Amana PTH093B35AM Thru-Wall/Window Air...
    I am looking for the reset button on my Amana heat pump the outside unit fan inside operates but the compressor does not run
    There are no simple reset buttons for that...
    Here is a tip about troubleshooting your airconditioner...
    There are many things that can cause your air conditioner not to cool...
    AirConditioner Trouble - Review the Possibilities
    heatman101
    Jun 11, 2011 | Amana Heating & Cooling
    Where is the reset button on an Amana ASZ14 unit?
    I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
    To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
    You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
    Here are some more repair tips...
    Heat Pump Troubleshooting & Repair:
    http://www.hometips.com/repair-fix/heat-pump.html
    Heat Pump Troubleshooting Repair
    Amana ASZ14 web page:
    http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
    ASZ14 Heat Pumps
    Amana ASZ 14 SEER Technical Manual
    (45-page PDF):
    http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
    Amana ASZ (and ASX) Service Instructions (66-page PDF):
    http://www.acdirect.com/media/catalog/files/RS6200006.PDF
    Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
    Amana PTH153B50AM AC works, heat doesn't. Is there a reset?
    there might be a reset button on the heat protector / you just might have a bad heat protector or the sensor on the board could be burnt out
    Oct 07, 2010 | Amana PTH153B50AM Air Conditioner
    Looking for manuel reset on heater amana ptac unit heat won't come on new control board
    I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
    Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
    Amana air and heating unit model # ptc153b50am w/ power cor 37470
    Sounds as though the power cord reset switch might be bad and need to be replaced. If not, then there is a short somewhere in the system. Do an ohms test on the switch to determine if it is bad.
    Mar 16, 2009 | Amana PTC153B50AM Split System Air...
    Amana PTAC PTC093A35AA won't blow heat
    The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
    That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
    Please remember to rate this fix.
    Jan 23, 2009 | GE Zoneline AZ38H12DAD Split System Air...
    Amana PTAC
    Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
    Nov 18, 2007 | Amana PTH123B25AJ Heat Pump Air...
    Heating & Cooling Logo
    146 people viewed this question
    Top Amana Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
