Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
How to change outside light bulb on 2008 puma camper. no screws in lens, does it pop off
Replacing license plate bulb 2008 Honda Odyssey how do I replace the bulb
often have an access panel you can remove to acces the bulbs from the rear door on the inside, if not you must remove the light fixture from the outside either my removing a screw holding the light housing or carefully pulling the plastic lens out, generally there is a or multiple screws holding the light fixture in place.
Jan 30, 2017 | Honda Cars & Trucks
Have a after market truck bed cap and can't tell how to change brake light bulb. No access panel and no scews holding lens down.Just wire going through fiber glass inside cap. Do you pry the lens open
What brand is the Truck cap? but yes generally if there are no screws in the lens front or back then there is usually a very small slot someplace on the edge of the lens you should be able to fit a small flat blade screw driver into and pop the lens. If the lens is surrounded by a rubber gasket on the outside the gasket usually has to be pried back before the lens comes out
Oct 27, 2016 | Cars & Trucks
How to change your dome lights in a 2008 tacoma
With door closed, use a coin to pop off the lens, Pull out the bulb glass looking thing and snap in a new replacement from the autoparts store. replace lens in it's proper spot
Mar 04, 2013 | 2008 Toyota Tacoma
How do I change a front marker light on a 89 GMC PU
There are a few different models, but the general procedure is the same. There should be Phillips screws holding in the plastic lens cover which are accessible from the outside of the vehicle. Unscrew these, and the lens should pop out to give you access to the rear. The wires to the bulb socket will come out with the lens. With the lens removed, the bulb socket is usually attached to the back with a half-turn twist. So, untwist the bulb socket and remove the bulb and socket from the lens. Now, push down and twist the bulb to the left in a simultaneous motion and the bulbe should pop out. You'll probably have some grease on the bottom of the bulb, which is dielectric grease to keep the contacts from oxidizing.
Take the bulb to your retailer and match the number on the brass base of the bulb to a new one. Installation is just the reverse of the removal.
Incidentally, some car and truck models have an alternate arrangement where you remove the bulb socket from inside the engine compartment (or trunk) and removal of the lens isn't necessary. If you don't see screws accessible from the outside of the lens, then pop the hood and see if you can reach your hand inside to where the bulb socket attaches to the lens.
Nov 25, 2010 | 1989 GMC Sierra
How do i change rear turn signal bulb
I just watched the service station replace the rear turn signal bulb of our 2008 Enclave in about 5 minutes for $30! He opened the tail gate door, there were two small squares in the black lighting panel trim that he popped open. Inside each was a screw that he removed. This enabled him to remove the whole lighting panel. He then twisted the bad bulb and removed it and replaced with a new one. He checked that it was working then popped everything back into place added the screws and closed the squares back up. DONE!
Sep 10, 2010 | 2008 Buick Enclave
How to change a tail light bulb on 2008 malibu? Not the version with the wingnuts, but the "Up Model" version that says call the dealer.
  1. Step 1 Determine how the bulb is accessed: On some models the lens (the red or white plastic part over the light) must be unscrewed from the outside, and on others the bulb is accessible only from inside the trunk. If there are no screws on the lens, you can assume that the bulb must be replaced from inside. Usually there will be a plastic cover that must be removed in order to access the bulb. There may be tabs, screws or small knobs that hold this plastic cover in place.
  2. Step 2 replace-tail-brake-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.2-800X800.jpg'); }); Unscrew the lens on the outside, or take off the plastic cover from inside the trunk, to reveal the bulb.
  3. Step 3 replace-tail-brake-1.3-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.3-800X800.jpg'); }); Unscrew the bulb. You'll have to push in and turn at the same time.
  4. Step 4 Take the bulb with you to the auto supply store to help you find an exact duplicate.
  5. Step 5 replace-tail-brake-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.5-800X800.jpg'); }); Clean the connection with a wire brush and/or wipe it clean with a rag if there's any corrosion.
  6. Step 6 replace-tail-brake-1.6-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.6-800X800.jpg'); }); Screw the new bulb into the empty socket. Again, you'll have to push in and turn simultaneously. Line up the tiny raised bumps on the base of the bulb in order to screw it in.
  7. Step 7 Replace the lens or the plastic cover.
  8. Step 8 replace-tail-brake-1.8-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep8 span.image a:first').attr('href','http://i.ehow.com/images/a00/02/i7/replace-tail-brake-1.8-800X800.jpg'); }); Test your work by stepping on the brakes and turning on the headlights while a friend watches the new bulb to make sure it lights up.
Jun 03, 2010 | 2008 Chevrolet Malibu
How do you install turn signal lens on side mirrors on a 2005 F250?
- Adjust the mirror so the mirror glass is in as far as it will go (meaning if you were looking in the mirror you would see the side of the truck)
- Look inside the mirror housing
- Locate silver clip
- Using a flat screw driver, push the clip in
- Lenses will pop out on the outside
- Remove bulb
- Replace bulb
- Snap back together when new bulb in place.
May 02, 2010 | 2008 Ford F-250 Super Duty
How do i change the brake bulb for my 2007 mercury mariner? I have already removed the 2 screws on the inside section of the rear tail light lens, but something is keeping it connected on the outside of...
Are you positive that there are only 2 screws? If so give a good push with your thumbs near the ceanter of the assembly it should pop out. If not theres another screw that your missing.
Jul 29, 2009 | 2007 Mercury Mariner Premier 4WD
Change a turn signal bulb on a 2008 Camry
you can see two screws holding this lens assembly, remove them and you can slide the lens off the cavity.
the wires and socket would be exposed, twist the socket counter clock wise and the bulb would be exposed.
replace the bulb and do the reverse in installing the signal light assembly back to the cavity.
tnx 4 using fixya,
drcool
Nov 16, 2008 | 2008 Toyota Camry
Replace passenger side power mirror clearance lamp (bulb only).
If you are facing the passenger side mirror adjust the top (large) mirror so that it is turning in towards the truck as far as it will go. Then look behind the mirror in the bottom righthand corner (outside bottom corner) and you will see a silver metal clip. Take a straight head screw driver and push on that clip and the lens will pop out. Then you simply unscrew the bulb holder from the lens and replace your bulb. Good luck!
Oct 16, 2008 | 2008 Ford F-350
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
102 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
