Question about Xerox 8830 Copier
Copier only copies half a page and then the bottom half on the next page consecutively
    New Friend:
  • 51 Answers
Switch off the machine then switch on after five minutes if problem exists replace its firmwares
Posted on Dec 12, 2010
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
Bottom of the copies are darker than the top I
There may be spilled toner inside the copier, Free the drum and paper way of toner an ensure the toner container is not over full. do proper cleaning and the copier will be okay.
Jun 10, 2010 | Kyocera Mita KM-2050 Printer
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Copies get a black line done center and alsio copies get a shadow of the original half way down the copy, like it is copying it again only lower on the page.
please next time post and the machine brand and model we are not able to help you if we do not know the brand and the model Regards
Jan 26, 2010 | Office Equipment & Supplies
Sharp Al 1631 prints half a page
Sometimes the originals hesitate using the document feeder, which can cause the problem you are describing. Do you get the same rsults if you lay the original on the glass?
Apr 29, 2009 | Sharp AL 1631 Copier
Sharp AL 800 won't copy bottom 2 inches across page. Replaced toner cart and still missing bottom 2 inches across page. What do I try next?
Pretty sure you need to replace the drum cartridge. When the drum blade goes bad or edges of the drum go bad it will cause this issue. You can stop a copy as it is passing thru and compare the edge as it is being transferred to the drum and what is on the paper to see what I am talking about.
I can be more specific if necessary
Thanks
TankMurdock
Apr 24, 2009 | Sharp AL 800 Copier
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
Scanner problems on HP Photosmart C4180
you need to lee at your printer seting
Nov 18, 2008 | Office Equipment & Supplies
Help needed on ricoh ft 4015 copier
1-you need to determine if the two are part of the same problem
If the jamming occured first with no signs of copy quality issues then, it depends on where it's jamming. Locate the 1st jammed paper, the one that is furthest towards the exit. this stops all other paper after it. for example if there are papers in the fuser -by the drum and coming out if the tray the problem is most likely in the fuser area. Are the papers being crumbled? or just stop at that location?
2-the half dark copies could be a couple of things
a) the seperation unit is going bad and making the copies rise up against the drum
b)does the lamp that come on to scan the original stay on the whole lenght of the paper or does it turn off half way down the page? if yes the cable that connects to the lamp is probably broken and not making contact at the half way point as it is scanning.
Sep 17, 2008 | Office Equipment & Supplies
Toshiba 3160 copier
Would you say that the bottom half is Ghosting? if so then the fuser hot roller teflon has worn and will need replacing.
If not please check the optical mirrors (Do not remove them only remove the top glass) for dust.
Sorry cannot be anymore help as you may possibly need a engineer call out.
Thanks J
Jan 16, 2008 | Toshiba 1360 Black and White Copier
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
