Question about Radio Shack Audio Players & Recorders
How to wire in 12 8 ohm speakers to a 100 watt amp.
  • Skyliner6605 Sep 07, 2010
    Thanks hope I got this right, sure would be nice if you could furnish a drawing. From what I gather you hook 3 speakers in series and then parallel them into one set.Do the same for the next set. Then take and hook the + from one set of six to the + of the other six, do the same for the - . Then hook the wires from the amp to the + and - of all sets.
    IO----O----OI
    ----I I----
    IO----O----OI
    Above is one set I assume the other set is the same, I then tie them together + to + - to - and then back to the amp.
    Genius:
  • 1,175 Answers
Make 4 sets of 3 speakers each. Wire each of 3 in series.+ to - and + to - and + to -. Do this for all 4 sets.
Then wire one set + to another set + and - to - ( parallel)
Wire the 2 remaining sets the same way
Then, wire the + from one 6 spkr set to the other + of the other 6 sprk set. Wire the ( - ) to the remaining ( - ).
This will all total 6 ohms which the amp can drive.
Posted on Sep 07, 2010
  • Scott Frye
    Scott Frye Sep 07, 2010
    I believe you understood exactly what I was describing
    Good job
I need to know the ohm rating for the speaker in a
Judging from the "10D", that most likely means 10 watts. 6.5 inch speaker, probably 8 ohms. Most amps of this nature have 8-Ohm speakers.
Their 12-watt and 15 watt amp have a 6.5". Their 20 watt amp has an 8". The 80 watt has a 12".
Hope this helps.
Mar 28, 2010 | Peavey Pv 2600 Power Amplifier
I NEED TO KNOW HOW TO WIRE THREE 3012 THWELVES TO A 1800 WATT KENWOOD AMP
Its hard to tell what you can or cant do without knowing exactly which kenwood amp you are using. Generally speaking though most kenwood amps are stable only down to 2 ohms. you will be better off just using 2 of your 12s wired in parallel- that will give you a 2 ohm load. There is a way to use all 3 simply by wiring them in series, it will end up giving you a 12 ohm load on the amp though which will work fine but you wont ever achieve the full power that the amp can do.
Jan 17, 2010 | Kenwood Kfc-w3012 12" 2400 Watt Car Subs...
How much is this mrv t320 amp and is it good for a 12 p3 rockfordfosgate?
If the Alpine is run bridged at a 4 ohm impedance then yes this would be fine. The amp is 400 Watts x 1 at 4 ohms. The P3 ha a 500 Watt rms rating. Just verify the impedance of your speaker. If you have a DVC 4 ohm speaker if wired in parallel you would present a 2 ohm impedance to the amp, that is bad. What is the impedance of your speaker?
Dec 24, 2009 | Alpine MRV-T320 Car Audio Amplifier
I have an Audiobahn A8000T amp and 2 12" Kicker CVR (DVC) Dual voice Coil. The Subwoofers are 2OHM a peice. What is the best way to hook this all up to run a 2 OHM load to my subs?
This is a link to Kicker for your CVR12 Subs...if you have the 2 ohm version (2 ohms per voice coil) and you have 2 speakers ....you will need to wire EACH speakers voice coils in series to get 4 ohms from each speaker and then wire the 2 speakers in parallel.....as in....2 ohms in series with 2 ohms = 4 ohms....both speakers wired same way, then in Parallel with each other = 2 ohm load. Page 2 of this link gives examples of both series and parallel wiring of your speaker.
http://www.kicker.com/sites/default/files/2006CompVX.pdf
If you are still not sure as to my description of ' How To',
PLEASE respond and I will attempt to explain it EXACTLY via wiring directions.
Nov 18, 2009 | Kicker CVR12 Car Subwoofer
2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
Nov 12, 2009 | Kicker KX2500.1 Car Audio Amplifier
Need help wireing sub
Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to rockfordfosgate.com they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
Oct 08, 2009 | Car Audio & Video
Amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
I have a memphis amp that puts out 250 watts @ 4ohms and 500 watts @ 2 ohms. I want to hook up 3 sony 12'' explods @ 4 ohms a piece. How do I wire them to the amp to get the maximum output of 500 watts?...
well to be honest your amp probly cant handel 3 speakers because of the impedance levels so just hook up 2 bridges out to + to - on one Speaker then from that same speaker run + and - to the next one
A= amp
S= speakers
A:::::::::::::::::::::::::::::::S:::::::::::::::::::::::::::::S
Mar 22, 2009 | Car Audio & Video
63 people viewed this question
Top Radio Shack Audio Players & Recorders Experts
 Grubhead
Grubhead
Falling star
Stuart Slabber
Level 1 Expert
Are you a Radio Shack Audio Player and Recorder Expert? Answer questions, earn points and help others
