Question about Kenwood Audio Players & Recorders
I have a Kenwood turntable model # 1500 that needs a belt. Can you tell me 1. how to replace it and 2. What belt to order and how much it should cost?
  • Kenwood Master
  • 3,740 Answers
You need the FTBM22.4 belt and can find it here: (see your model number) $9.95 + $5.99 shipping US
http://www.studiosoundelectronics.com/turntable.htm
To change the belt you remove the rubber from turn table and then using the finger holes press on the center post while lifting the turn table off.
See this link with pictures:
http://www.studiosoundelectronics.com/turntableinst.htm
Thanks for choosing FixYa.
Kelly
Posted on Aug 31, 2010
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
I have two problems. One: Does the Kenwood KD34R Turntable does it need a system cord? Two: I have a Kenwood KD491/492F turntable, it drags. It has a new belt. Please help. Thank you.
just had that problem when i replaced my belt on a pioneer pl600 turns out there was residue from the old belt on the drive pulley making the belt ride on the edge of the pulley instead of in the groove there is also two adjuster screws under the turntable that u took off to replace the belt with these u can adjust the speed manually was told that by a repair person from vintage electronics great place online for help
Sep 29, 2013 | Kenwood Audio Players & Recorders
I need to fit the replacement turntable belt on my Kenwood stack system record player
Hi, we have all Kenwood belts in stock. What model do you have. Cheers John. Styluscity@gmail.com
Aug 09, 2011 | Kenwood Audio Players & Recorders
Speed seems to be slowing down every so often but then it will resume speed
Chances are you need to replace the drive belt.
These are easily available online (try Ebay or Amazon) just search by make and model number.
To access the belt you will normally need to turn the turntable upside down and unscrew the base.
Feb 17, 2011 | Kenwood Audio Players & Recorders
I replaced the belt recently on an old Technics turntable and now the speed is noticably inconsistent. I ordered (supposedly) the correct belt for the model. What are the possible causes?
2 possible causes:
1 - the belt slips - take it out and clean the drum and the motor pulley with alcohol.
2 - when you have installed the belt you have accidentally misaligned the speed sensor - take the drum out and check the contacts at the sensor and its position.
Aug 18, 2010 | Technics Audio Players & Recorders
Kenwood Trio Turntable belt broken.
I have them listed as item 250423608612 on Ebay .. softwaredivision
Feb 07, 2010 | Audio Players & Recorders
Higher speed on 33 rpm
maybe your turntable belt has stretched causing it to slip and speed up? go to http://www.needledoctor.com/Online-Store/Turntables and order a replacement belt. good luck
Sep 11, 2009 | Kenwood Audio Players & Recorders
Kenwood turntable cover hinge replacement
Yes they can be replaced.
Contact the store you purchased it from or ask where they have repairs done. They should be able to order the parts for you.
Sep 11, 2009 | Kenwood KD-291RC Turntable
How do i put turntable belt back on?
you must first get the platter off [the bit that you put the record on ]
this will prise off with equal pressure on both sides but remove the rubber mat on the platter first [it might have a little clip on the centre spindle if so just get a screwdriver and push the clip off ] then just jiggle the platter with your hands until it frees , when off you should see a small round disc thats connected to the motor that turns the platter via a rubber belt , you just connect the new belt around this and then connect the other end to the platter very fiddly , not being familiar with kenwood turntables i could be totally wrong here and the belt might go to another pulley in which case you might need more than one belt , your best bet is to get the platter off and let me know what it looks like
May 23, 2009 | Kenwood Audio Players & Recorders
Stylus for a Kenwood Belt Drive Turn table
I suggest try 'Lpgear@yahoo.com' There is a long list of Kenwoob turntable cartridges & needels. I hope you find your needel.
Sep 18, 2008 | Kenwood KD-291RC Turntable
75 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
