Question about ViewSonic NextVision N2010 20 in. LCD Television
How do i unlock the power button on a n2011 viewsonic tv
The menu button is locked on my view sonic tv how do i unlock it????
Depends on the model of TV. Some ViewSonics will unlock the menu if you Press the Channel + and Channel - buttons at the same time. You should see a message stating the menu is unlocking. Once it clears you can use your remote control to make any necessary changes to the TV.
Sep 25, 2010 | ViewSonic N2230w 22 in. LCD TV
Tip
Viewsonic monitor Lock and Unlock instructions
OSD and Power Lock Settings
OSD Lock: Press and hold [1] and the up arrow UP for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
OSD Unlock: Press and hold [1] and the up arrow UP again for 10 seconds.
Power Button Lock: Press and hold [1] and the down arrow DOWN for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display?s power will automatically
turn ON when power is restored.
Power Button Unlock: Press and hold [1] and the down arrow DOWN again for 10 seconds.
May not work on ALL Viewsonics
http://www.viewsonic.com/assets/027/7939.pdf
Service manuals: http://ftpkuban.com/FTP/Manual/ViewSonic/
on Apr 14, 2010 | Computers & Internet
N2635w 26 in. LCD Television: help me unlock my viewsonic...
try pressing and holding one of the "channel up" or "channel down" buttons for 5 seconds or more... While holding the button, you should see a progress bar that indicates "menu locking" or "menu unlocking". That should fix your problem...I found that out by accident on my TV.
May 10, 2010 | ViewSonic N2635w 26 in. LCD Television
ViewSonic VA2226W LCD Monitor unlock power button
Try holding the vol+ & vol- or hold the vol+ & Menu and lastly try the ch+ & ch- buttons. When doing this you must do it from the tv not the remote, and hold them down for ten seconds or until it says it has unlocked.
Apr 04, 2010 | ViewSonic VA2226W LCD Monitor
I have a viewsonic VT2430 everytime i press a key on the remote and on the tv it says "button locked" how do i unlock it?
Hold down the volume buttons on the tv itself and it should display "unlocking buttons". Hold them down until it says ""unlocked".
Jan 27, 2010 | ViewSonic VT2430 LCD TV
I have a Viewsonic flat-screen tv, it displays "menu locked" ??
Try holding the VOL + and VOL - buttons on the TV (not on the remote) down together. You should see a "unlocking buttons" message on screen. This might work. However, I tried it repeatedly, as told to by the Viewsonic "service" rep, and it didn't work for me. Viewsonic is ****, and so is its "service"!
Jun 06, 2009 | ViewSonic N3251w 32 in. LCD HDTV
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
Viewsonic power lock
On the tv itself hold down channel up button while holding that press and hold the menu button . this will un lock it
Dec 29, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
3735w Viewsonic Power lock problem
I had the same issue on my Viewsonic N3752w
The online guide, said I had to press VOL+ and Menu at the same time, but forgot to say
a) it's from the TV buttons NOT the remote!!!
b) you need to keep pressing these 2 until it stop saying "Power unlocking" but Unlocked.
Sep 14, 2008 | Televison & Video
WHAT IS OSD ON A VIEWSONIC N 2011
OSD is basically the on screen display, meaning the various menu options that appear on the screen. You can turn it off by hitting the menu button on the remote till it disappears. Here is a user guide for your TV:
http://www.viewsonic.com/pdf/userguides/n2011-1_ug_eng.pdf
If you found the answer satisfactory, kindly take a moment to assign a Fixya rating. Thanks in advance..
Jun 08, 2008 | ViewSonic NextVision N2010 20 in. LCD...
ViewSonic NextVision N2010 20 in. LCD Television Logo
155 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
