Question about Motorola For SP50 7.5v 1500mAh NiCd Battery 2-Way Radio
1972 monte keeps wearing battery down,what is the problem. i've already put a new alternater on and the car does sit in the garage alot
    Problem Solver:
  • 19 Answers
You seem to have your car confused with a Motorola radio battery. This may be part of your problem.
Posted on Sep 07, 2010
Ford fiesta alternator problems
Yes, it is a difficult job unless you are an expert mechanic. if you take it to the garage you will save alot of grief. Not an easy job to do in driveway.
Aug 10, 2012 | Ford Vehicle Parts & Accessories
How to change an alternater on my 2001 chevy monte carlo
pull neg battery cable take off wire, unplug plug,remove belt , one bolt on top one on bottom use pry bar to loosen and remove install in reverse order make sure battery is charged before start or damage to new alternator may occur,
Aug 04, 2012 | 2001 Chevrolet Monte Carlo
I've changed the alternater,starter, voltages
Troubleshoot first and then change parts! What was the original problem? It just won't crank over? The alternator just charges the battery the voltage regulator keeps from putting too much of a charge into the battery. Was the battery going dead? Did the vehicle start when jumping it with jumper cables? Too many unanswered questions to offer help, sorry.
Feb 26, 2012 | 2007 Ford Van E-350
Battery not charging has a new alternater and starter think the ground may not be right starts if i charge the battery but wont run once it uses the charge i put on the battery
IF IT DRAWS DOWN WHILE SITTING OFF U SHOULD HAVE SOMETHING DRAWING POWER IF SO DISCONNECT CABLE WHILE IT SITS RECONN WHEN READY TO START IF U HAVE JUICE TO START THEN SOMETHING IS DRAWING CURRENT TRUNK LIGHT AMP SHORTED SWITCH ETC!! HOPE THIS HELPS!!
Mar 06, 2011 | 1996 Chevrolet Cavalier
I have a1975 corvette and the steering swirls to the left when driving, it has new tires and the balance and alignment was done.
Could have a broken spring... or shock...
You didnt say if this happend before or after you took it for the tire and balance?
Depends how they Jacked up the car to change tires maybe spring isnt seating right..
Oct 28, 2010 | 1972 Chevrolet Corvette
1999 toyota battery keeps going down with new alternater this makes 2 alternaters and batteries
The most likely cause if you have changed batteries and replaced the alternator is that you have something that is an electrical drw when the car is shut off.
I assume the battery goes down while the car is sitting?
If it goes down when you are driving, it is likely a different problem.
If you don't have a multimeter to check for current draw when everything is shut off, an easy test to remove the negative battery cable and let it set the time it takes to discharge.
Then hook it back up and see if you have a full battery. If it doesn't go down with the batteryt cable disconnected, you either have a short somewhere or there is something left on (like a glove compartment or trunk light) that is draining the battery.
I assume you checked for the obvious things like brake lights staying on when the car is shut off (brake light switch problem).
Oct 01, 2010 | Toyota Tacoma Cars & Trucks
My kia sephia 2000 turn signal comes on and then stops alot then after driving for awhile it comes on normal can you tell me whats wrong
I have a 2000 kia sephia, i have went through 3 alternaters including brand new in 2 days. The alternaters are not charging my battery and burning the alternaters up with in minutes of putting them on. My engine light is blinking about 40 times. When i turn the trun signals on my speedometer an rpm gage jump up and down.
May 20, 2010 | 2000 Kia Sephia
Thank you for you help-- is a 1983 monte carlo 305 engine --The volts gage is dropping considerably. wen i start driving alternator brand new , battery good ,starter is good,wen the car is park my volt...
Check the votage of the battery with a volt tester in the DC mode and the probes reversed ( black on red red on black) if a reading of voltages shows of any amount, the diode is bad in the altenator
Mar 23, 2010 | 1983 Chevrolet Monte Carlo
Motorola For SP50 7.5v 1500mAh NiCd Battery 2-Way Radio Logo
27 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
