Question about Hyundai Audio Players & Recorders
Woofers and sider speaker not working. In the sense out of five speakers only two functioning. Not having mannual to set speakers. Model Hyuandai - HT 719DVK, DVD Hometheater. Appreciate if you can send the speakers setting manual on management@imc-dubai.com Thanks Vivek Wani Head - BD Internaitonal Management Consultants Dubai www.imc-dubai.com
  • 52 Answers
The unit has to set in surround mode. There should be a button on the unit that says surround or effect..
Posted on Sep 01, 2010
I have an technics su-g75 and all of a sudden I lost all sound from the bass speakers I only have treble and mid tones that play out of my speakers
As far as I know, that model doesn't do biamp functions, so it wouldn't be the amp being the problem, although it could have caused the problem with the speakers. I suspect you have blown your woofers. It's odd if both L+R cabinets went at once, which leads me to question weather the amp send a subsonic signal to cause the failure. That assuming you weren't playing more loudly than the cabinets were rated for. I suggest checking the woofers for being b lown, and then taking the amp to the shop for a checkup.taking the amp
Jan 22, 2016 | Technics Audio Players & Recorders
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
The amplifier power ligh comes on but the sub woofers wont play what could be the problem. I hooked up a different amp and it worked just fine.
Even tho the power light is on doesnt exactly mean that the amp is sending signal to the speaker wires.... sense everything else is working make sure to check your fuses on the amp and also check to make sure that the amp is "receiving" an input from the RCAs
Feb 25, 2011 | Car Audio & Video
My sub woofer stopped working, please tell me where it is located so i can check the speaker and also check if power is going to it thank you very much joe
The JBL premium sound system has a large woofer in the bottom of each door, a small mid-range speaker next to the woofer, & tweeters next to the front door windows in the corner, & two full-range speakers near the rear seats. The woofer (not sub-woofer) handles all the low end. You can test the woofer by turning the BASS to max and TREBLE to minimum (make sure balance and fader are centered) and put your ear next to each woofer.
The woofer is usually the 1st speaker to have problems after 10 years or so. The outer edge of the woofer starts to degrade. You will usually hear a rattling sound out of the woofer when this happens.
NOTE: If no sound at all out of the woofer (tweeters are OK), you might take your car into a car stereo shop. They can put a speaker on the wires connected to the speaker and make sure your problem is not the radio.
PROBLEM: You can still hear sound out of the woofers but it is distorted
SOLUTION 1: Go to a car audio shop and have them install new woofers. These may cost $30+ each but the dealer cost is over $200 for each woofer (crazy).
SOLUTION 2: More involved but very cost effective. If you or a friend is handy, you can go to www.speakerworks.com and order a new set of speaker outer rings (on the site they are called speaker SURROUND) that will replace the damaged outer rings on the woofers (replace on both woofers). They really work great and your speakers should last for many more years.
Hope this helps.
Feb 07, 2011 | 2001 Toyota Sequoia
How do i install the movon bluetooth car kit, i lost the manual
The entire devinces of hardware have to be installed to attain power functionality before bluetooth is attainable. First, install new stereo into the socket area with appropiate wiring links attacked to power cuicuits. Second, install the woofers speakers into places firmly attaching to copartments. Connecting links to the stereo that would be produce media with woofer into speakers. Third, once the stereo devices are connected ready to produce the first audio effects, bluetooth is capable of beign set with the features on the stereso.
Jan 28, 2011 | Car Audio & Video
I can't hear any sound through my computer. I hear the connection but nothing will play.
check in control panel.
check sounds and settings.
go into loudspeakers, and check that all siders are up.
I hope this was helpful.
Jan 11, 2011 | Logitech X-230 Computer Speakers
Pioneer cs-g404
My experience with them is that they would work as they don't change much from model to model year. You may call the customer support and they will most likely help you
try CS @ 800-421-1404 or try the parts hotline to investigate
(800) 228-7221
Mar 15, 2009 | Pioneer CS-G204 Speaker
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Output problem - i think
Based upon your description, I would suspect the speakers not the receiver. Typically, if the receiver was bad, there would be no sound at all. If the front end of the receiver was bad, this symptom could happen, but that is a rare problem. Can you try a different set of speakers? A or B won't make a difference from the receiver. Pleaes try another speaker set and update this with the results and we'll continue on from there.
Thanks,
Dan
Aug 27, 2008 | Pioneer VSX-D608 Receiver
Defect woofers
If you can get the same woofers, then yes you should be OK, pull the units, get the part number off the back and then try Google for a source.
If you can't find a exact replacement then you are looking at replacing all of the woofers, rule of thumb is that you do not want to mix speakers, you end up having one speaker sounding different than the other, so what ever you do to one, you need to do to the other. In that way what tonal changes that happen will happen to both speakers and they remain matched.
Now if you need to find replacements, you need to replace with like impedance speakers, and try to find a speaker very similar to what you are replacing. Just don't throw anything in the cabinet, if the impedance isn't correct not only the sound could be bad, but you could also damage your Amp or Receiver.
john
Aug 17, 2008 | PSB Image 4T Speaker
212 people viewed this question
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Steven Mitchell
Steven Mitchell
Andrew Taylor
Andrew Taylor
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
