Question about Canon i80 InkJet Printer
When I try to print on my Canon i80 pringer, a message comes up - Waste Ink Absorber is almost full. How do I empty it?
    President:
  • 414 Answers
Try using original cartridge...
Posted on Aug 31, 2010
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Need to replace Waste Ink Absorber on a Canon i80 printe. A window keeps coming up and now I can,t print any thing untill I replace this absorber. I can't even find it.
The absorber on this model runs across the back and looks almost like a C cell flashlight. It's called the drain pack assembly, #QL2-0194-000. It's tough to change and after you need to access the service mode to reset the counter.
Dec 31, 2009 | Canon i80 InkJet Printer
Waste ink absorber is full contact service center message
waste absorber full reset sequence for the I80.
1)Turn off the printer. Press and hold the Resume/Cancel and Power buttons at the same time.
2)Release the Resume/Cancel button. (continue to hold down the power button)
3)While continuing to hold down the power button press the Resume/Cancel button 3 times then release both buttons.
4)The LED should now be green. Press the Resume/Cancel button 4 times. The led should be green.
5) Turn the printer off and then back on. You should be good to go. Unfortunately when the tank gets completely full it will stop printing. The cost of repair however is more than the cost of replacement.
Jun 03, 2009 | Canon i80 InkJet Printer
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Cannot find information on waste ink absorber for Canon i80
The waste ink absorber collects any spilt in from the head and stops it leaking out or sitting in the bottom of the printer casing. The printer is telling you that the one in yours in nearly full. You know have two options:
1. Replace the waste ink absorbers and reset the counter (will require taking the printer apart)
2. Reset the counter only (you run the risk of ink leaking out)
The waste ink absorber for the I80 can be got quite cheaply if you google about.
You can reset the counter by:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press
the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power
and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights
alternately in either orange or green, starting with orange.) During initialization, the LED blinks in
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times.
Hope that helps
Nov 16, 2008 | Canon i80 InkJet Printer
Canon i80 InkJet Printer Logo
340 people viewed this question
old marine
old marine
