SOURCE: CD Stuck in cd player
There should be a reset button on either the face of the player or under the faceplate if its removable (tiny black button). Otherwise to remove the cd disconnect the unit and then plug it in or remove the memory fuse or battery lead for 5 seconds.
SOURCE: it dont play & the cd is stuck in the player
Go to Start, control panel, system, device manager, find the device and uninstall it. then reboot, see if that helps
SOURCE: i have a kenwood dp-r99 cd player and the cd is stuck
6 or 7 phillips head screws. 2 or 3 across the back and two on each side. Slide the top towards the back then up. You will be able to get to all CD's with the top off. Hope this helps
SOURCE: dvd player is stuck,cd is inside it is not ejectiong
I am a 63 yr old female and I have just took the lid off mine and got the DVD out and it is working ok now
SOURCE: Cd stuck inside of laptop,
Look here: Remove CD Rom
Scroll down to see how to remove the drive
Open the tray slightly before you remove the drive.
24 Way F Micro-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A1
PPL
1952
RH Front Tweeter Output -
A2
LT GRN
1852
RH Front Tweeter Output +
A3
BLK
1856
LH Front Tweeter Output +
A4
YEL
1956
LH Front Tweeter Output -
A5
DK BLU/WHT
346
Rear Shelf Subwoofer Coil 1 Output +
A6
LT GRN/BLK
1794
Rear Shelf Subwoofer Coil 1 Output -
A7
YEL
1860
Center I/P Midrange Output +
A8
LT BLU
1960
Center I/P Midrange Output -
A9
DK GRN
1795
Rear Shelf Subwoofer Coil 2 Output +
A10
LT BLU/BLK
315
Rear Shelf Subwoofer Coil 2 Output -
A11-A12
Not Used
B1
DK GRN/WHT
368
Right CD Changer Input
B2
BLK/WHT
372
CD Changer Common
B3
BRN/WHT
367
Left CD Changer Input
B4
LT GRN
1948
Right Audio Input -
B5
LT GRN/BLK
512
Right Audio Input +
B6
DK GRN
1947
Left Audio Input -
B7
TAN
511
Left Audio Input +
B8
DK BLU/WHT
653
Chime Input/Return
B9
PPL/WHT
652
Chime Input +
B10
Not Used
B11
PPL
1807
Class 2 Serial Data Line
B12
PPL
1807
Radio Amplifier (UX8) C3
Connector Part Information
12064749
2 Way F Metri-Pack 480 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
651
Ground
B
RED
1242
Battery Positive Voltage (B+)
Check
24-Way F Micro-Pack 100 Series (GRY) (Except UQ7 w/o Y91)
15428074 (UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRN) (UQ7 w/o Y91)
Pin
Wire Color
Circuit No.
Function
A1
ORN
1044
Radio Class 2 Serial Data
A2
Not Used
A3
PPL
493
Rear Seat Audio Enable Signal (UQ7 w/o Y91)
A4
RED
1486
FM Composite Signal (UQ7 w/ Y91)
A5-A7
Not Used
A8
TAN
201
Left Front Speaker Output (+) (UQ3/UQ5)
A8
TAN
511
Left Front Low Level Audio Signal (+) (UQ7)
A9
GRY
118
Left Front Speaker Output (-) (UQ3/UQ5)
A9
DK GRN
1947
Left Front Low Level Audio Signal (-) (UQ7)
A10
LT BLU
115
Right Rear Speaker Output (-) (UQ3/UQ5)
A10
BLK
1946
Right Rear Low Level Audio Signal (-) (UQ7)
A11
DK BLU
46
Right Rear Speaker Output (+) (UQ3/UQ5)
A11
DK BLU
546
Right Rear Low Level Audio Signal (+) (UQ7)
A12
BLK/WHT
1851
Ground
B1
ORN
340
B2
Not Used
B3
PNK
314
Radio On Signal (UQ7 w/o Y91)
B3
DK GRN
145
Antenna Enable Signal (UQ7 w/ Y91)
B4
BRN/WHT
230
Instrument Panel Lamps Dimming Control (w/ Y91)
B5
BLK/WHT
1851
Ground (w/ Y91)
B6
GRY/BLK
2334
Radio Mute (UQ7 w/o Y91)
B7
Not Used
B8
BRN
199
Left Rear Speaker Output (+) (UQ3/UQ5)
B8
BRN
599
Left Rear Low Level Audio Signal (+) (UQ7)
B9
YEL
116
Left Rear Speaker Output (-) (UQ3/UQ5)
B9
DK GRN/
WHT
1547
Left Rear Low Level Audio Signal (-) (UQ7)
B10
DK GRN
200
Right Front Speaker Output (+) (UQ3/UQ5)
B10
ORN/BLK
1546
Right Front Low Level Audio Signal (-) (UQ7)
B11
LT GRN
117
Right Front Speaker Output (-) (UQ3/UQ5)
B11
LT GRN
512
Right Front Low Level Audio Signal (+) (UQ7)
B12
Not Used
