Question about Harman Kardon DVD47 DVD A/V Player ETA 4/06
No audio hooked up dvd player to samsung 40 inch lcd got picture but no sound sometimes i get the back ground sounds though tried hdmi and optical and regular audio analog. Can some one help?
  • 1 more comment
  • addisangi Nov 10, 2008
    My dvd is NEC when I play a dvd disc I have picture but no sound
  • matthewacole Nov 30, 2008
    Hooked up H/K DVD47 to Samsung 32" Flat Screen via HDMI cable and get no sound.
  • steverosinsk Feb 21, 2009
    THERE IS a way to fix this... it's somewhere in the settings and has to do with how you have the DVD player setup, but I CAN'T REMEMBER HOW to fix this. It's doing the same, exact thing to us, right now, and I should have a sheet of paper, framed on my living room wall at this point... this is the third time it's done this to us since we've owned it.
    The solution isn't cords and such, though... it's fixable with your remote... keep looking online, and you should find the fix. If you do, post it, here, so I can use it as well. Sorry, I just can't remember what it was that I had to "enable" or "setup" or whatever... it'll come to me.
Try this link! It might be in the way your "stereo" settings are right now.
http://www.harmankardon.com/faq/showfaq.aspx?lstProduct=DVD%2047
Posted on Feb 21, 2009
Trying to hook up my dvd player,picture comes in black & white and no sound
Hi,here is my simple solution...
to listen your DVD on TV
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your DVD ,
** to both "AUDIO input " and VIDEO input" of your TV or "Optic Cable input"
** than just switch to respective mode on TV as A/V selection
of your RCA or Optic connection..
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
There you go..Both DVD sound and Video are on the TV .By this means whatever you watch on the DVD will come thru your TV.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jun 29, 2011 | Televison & Video
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
I have an Onkyo TX-SR606. With an HDMI connection from any dvd player connected to the HDMI/DVD in on the Onkyo I get perfect pic and sound initially then the picture starts to go bad, usually about 5 - 10...
Hook your HDMI directly ffrom the DVD to the TV, then connect digital coaxial or optical to your receiver for audio. Your receiver will not current HDMI video codecs. That is the only fix. Sorry. Hope this helps.
Sep 25, 2009 | Denon AVR-3806 Receiver
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Samsung surround sound wont connect up properly to samasung plasma tv
i have a plasma samsung 42 inch and i dont know how to connect my jacks red,white, yellow from the dvd to the plasma and what channel should the plasma be on to see the dvd ???? thanks anthony
Mar 28, 2008 | Samsung HT-Q100 System
Harman Kardon DVD47 DVD A/V Player ETA 4/06 Logo
184 people viewed this question
Top Harman Kardon Televison & Video Experts
Demonic-2011
Demonic-2011
Brett Duxbury
Brett Duxbury
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
