Question about HP Pavilion F1703 17" LCD Monitor
Monitor won't stay on. says check cable connection. I have bought new cables thinking this may be the problem.
  • 11,361 Answers
Since it is telling that it does not get the signal form PC, you should try it on another PC frst, if it still does not work then you will have to open it up and inspect the inside. It may have bad solder joints or bad logic board.
http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Aug 31, 2010
Will not power up. Power light stays on for about 30sec then blinks
Hello Friend,
1> Make sure the DVI connector is securely connected.
2> Unplug the power cable from the monitor few time.
3> Re-connect the power cable and power on.
4> if not solve then i think you monitor, not power supply working.
5> Change power cable.
6> Finally nearest touch good Technician.
Thanks....
Aug 22, 2013 | Sharp Aquos Televison & Video
Monitor says to check signal cable
get a new power cable for tower/computer. u can call i wat u want. new power cable for computer not moniter. or connection is incorrect. hope it helped.
Dec 05, 2011 | Samsung Computers & Internet
Suburban won't start, bought a new battery but does no thing, when jump started it stays running until it is shut off and will not start again
If you can jump start it and it stays running....I am assuming that you connect the Jumper Cable Ground to something other than your battery. If so, Your negative battery cable is suspect. Check both ends for ANY corrosion or loose connections.
Aug 18, 2011 | Chevrolet 1500 Cars & Trucks
Hi i have a compaq c7oo laptop it starts up fine but if you try and adjust the monitor it turns dark i have had an external monitor connected to it but it stays on while the laptop monitor goes dark if i...
In all likely hood, you have a loose connection or a worn LCD cable. This is a common failure in all laptops. If it is a loose connection, re-seating the connectors on both ends of the cable will cure this. If the cable has broken wires in it, it will have to be replaced. i would suggest a knowledgeable person or pro to tackle this for you.
Apr 07, 2011 | Compaq Presario 700 470024-192 Notebook
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
Computer has red tint!HELP!!!!!!!!!!
If it is under warranty, take it back. Elsewise caveat emptor.
Mar 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Just connected monitor won't come out of self check
Make sure your cable is the right one, and that it's truly well-connected to the monitor. My monitor stays in self-check when it's not receiving a signal from the ol' computer.
Jan 13, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor signal cable troubleshooting
hi, there is some loose contact in the connection. Take out the cable end from the VGA socket and check the pins inside the socket for any bend inside the socket. Reconnect it, tight the connector with the socket bolts. If not solved, try for any loose solder or wire breake.
Thank you
Jun 23, 2008 | IBM E74 17" CRT Monitor
Dell monitor
See the link below. White cable is better than blue. Don't connect both!
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&docid=306F260F75DAB073E040A68F5B284E6F&l=en&s=gen
Dec 22, 2007 | Gateway FPD2275W LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
69 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
