Question about GE Refrigerators
WE FOUND THE ICE CREAM TO BE SOFT IN THE REFRIGERATOR.BUT THE REST OF THE MEASTS WERE HARD AND SOLID.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice cream is the first thing to get soft....
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 01, 2010
Soft Ice Cream Machine
What make and model?
Jul 02, 2013 | Refrigerators
Ice cream gets so solid to tough to scoop
Depending on the brand of ice cream. The higher priced have more cream which causes softness.
Oct 11, 2010 | LG LRFC25750 Refrigerator French Door
2 months ago or so, found puddle of water in front of our freezer; about 1 month ago ice cream in freezer became soft. High temp alarm went off a week ago--I've checked the temperature intermittenly and...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 22, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
The ice maker is making 1 tray of ice a day
There are 3 things needed to make proper ice.
Water, cold, time.
Check the cubes that are being made, they should be the same size crescent shaped. If they are not solid and some are hollow or broken then you are not getting enough water to the refrigerator. This is usually caused by the little valve on your house piping that connects to the refrigerator being plugged with sediment.
If the the cubes are all solid and the same size check the temperature of the freezer, it needs to be below 10 degrees F and works best below 5 degrees F. If it is warmer than that it will only produce ice on a very slow schedule. If you do not have a thermometer ice cream is a good indicator of temperature. If ice cream is hard the temperature is below 5 degrees F, if it is soft you are not cold enough to make ice cubes either.
If all this checks out alright you may need to have the ice maker replaced. the modular ice makers are available for sale at most all part retailers.
Apr 19, 2010 | Kenmore 74822 / 74824 Top Freezer...
Ice cream is frozen solid hard.
Turn the temp down and put ice cream on the door.
Apr 16, 2010 | Kenmore 72073 Top Freezer Refrigerator
Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Oct 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Cream won't stay frozen it get's all soft and gross. Main things in the freezer stay frozen.
This is an easy one!!
Ice cream needs to be around -5 degrees to +5 degrees to stay frozen (or hard) if the freezer is at like 15 degrees the ice cream will be soft but the rest of the things like meat and ice cubes will be rock solid because anything lower than 32 degrees is freezing for those things.So you might wanna check to see if the fan motor is working and also make sure the condensor coil is free of debris.
Sep 20, 2009 | Refrigerators
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
My ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Soft ice cream
there are vent openings in the back of the freezer you should not block that ..it will cause the temp to go up
Jan 21, 2008 | Kenmore 72073 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
