Question about HP Photosmart C7280 Printer
I have an HP C7280 All in One printer. On occasion all lights start blinking. This has happend multi times. Now I have an issue that it will not come back online. I get a B811FCAA error on the screen.
JulesPCaut
  • 702 Answers
SOURCE: Uninstall HP image zone 5.3 installation - error installing hp c7280
Did you try an uninstaller program?
Also check out this article about fixing uninstall errors.
Posted on Apr 23, 2009
SOURCE: error msg on a c7280 hp printer
I had this exact same problem and it is truly frustrating! I finally stumbled on this link with a solution. The problem really is that when you make a custom size envelope you measure the envelope as you look at it for height and width, then you stick it in the printer with the longest side of the envelope against the long side of the printer tray, thus the printer is reading the dimensions of the paper in reverse of your custom size. Reverse your dimensions in the custom size set up and try again. This worked for me. Here's the link to the message I read that finally helped me to figure this out:: http://h30434.www3.hp.com/psg/board/message?board.id=Printing&thread.id=4369
Good Luck!
Posted on Jul 04, 2009
bandana_gyrl
  • 181 Answers
SOURCE: I have a printer ?HP c7280 All-in-one?a message,
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Jan 21, 2010
  • 30 Answers
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Posted on Jul 26, 2010
  • 44 Answers
SOURCE: My HP C7280 wireless printer is "ofline" how do I
Go to printer folder ( printer and faxes ) right click on the printer and choose " USE PRINTER ONLINE"
Posted on Nov 14, 2010
My HP Photosmart c7280 will not print pink or magenta. How can I fix this issue?
Sounds very much like you have a clogged printer head you should run the deep clean procedure form the printer dialog. If that does not fix the issue you may need to replace the print head.
Jan 28, 2015 | HP Photosmart C7280 All-in-One Printer
Hp c7280 making a loud noise when preparation is occuring
Loud noise is not usual. But you may try the below mentioned steps to check if it can resolve the issue.
While the printer is ON, remove the ink cartridges.
Unplug the Power cord from back of the printer .
Wait for 30 seconds.
Plug in the power cord to the printer.
Install the ink cartridges.
If issue still persists, please call HP Tech Support as it could be a printer hardware issue.
Jul 09, 2014 | HP Photosmart C7280 Printer
AirPlay HP Photosmart C7280
Yes you can.
I share a supported link please visit and read guide. I hope solved your issues.
http://support.apple.com/kb/ht4356
Thanks,
HP Printer Support
May 29, 2014 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart c7280 blinking
Which lights are blinking? If its related with cartridges.. replace them, if its related with print heads.. replace indicated one..,
Jan 30, 2012 | HP Photosmart C6180 All-In-One InkJet...
HP C7280 ink system failure error: 0xc18a0101
just had this exact issue with my C7280. I called HP Tech support, got a body in Bangalore or someplace, and was pleasantly surprised that they were prompt and knowledgeable, and solved the issue very quickly after transferring my call one time to a hardware support expert.
I hope this help those who have similar issues
Jun 16, 2011 | HP Photosmart C7280 Printer
When my Wi-fi connected HP 7280 has been turned off a few hours all lights start flashing. Pulling the plug and then putting it back solves the problem.
I think there's an easier way to fix that, The printer might just be offline that's why the light is blinking. Try this.
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Feb 04, 2011 | HP Photosmart C7280 Printer
My C7280 is printing at an angle
You could try the recommendations from HP support for your model: (recommend cleaning feed rollers)
HP Photosmart C7280 Prints Crooked
Jan 07, 2010 | HP Photosmart C7280 Printer
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
HP Photosmart C7280 Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
