Question about Suunto X6 (black) Wrist Watch
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • 831 Answers
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Posted on Aug 31, 2010
    Suunto Core watch - my watch is locked in the compass mode. How to I get it unlocked
    RTFM
    Suunto Core User Guide
    ns.suunto.com/Manuals/Core/Userguides/Suunto_Core_Userguide_EN.pdf
    This User Guide explains the Suunto Core features, how they work, and how ... nearest watch store to get the needed adjustments correctly done for you.
    How to Set Up a New Suunto Core - YouTube
    ? 6:49
    https://www.youtube.com/watch?v=_zywJcNNowU Jun 13, 2015 - Uploaded by Wearable4U
    Great tutorial, clear and precise (beats reading the manual) many thanks ;-) ... Hi there. Just bought a suunto core ...
    SUUNTO CORE USER MANUAL Pdf Download. - ManualsLib
    https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core user manual online. Suunto Core: User Guide. Core Watch pdf manual download.
    SUUNTO CORE QUICK MANUAL Pdf Download. - ManualsLib
    https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core quick manual online. Suunto Core: Quick Start. Core Watch pdf manual download.
    [PDF]Quick Guide - Trekkinn
    www.trekkinn.com/images/pdf/especificaciones/eng_suunto_spec_10086.pdf Suunto Core brings together an altimeter, barometer and an electronic compass ... Please refer to the User Guide for detailed information on setting these. Suunto Core watch Google Search
    Jun 17, 2017 | Suunto Watches
    Dull digits
    Time for a new watch if it wasnt the battery.
    Aug 12, 2012 | Suunto X-Lander Wrist Watch
    How to switch on suunto watch
    changed the actual electric battery upon my personal suunto vector view however cannot arranged time,and you can get a new led watch
    Apr 19, 2012 | Suunto Core Watches
    The ascent reading seems to be very inaccurate and the battery shows low after only a couple rides after installing a new battery. Anyone have a solution for the acent issue?
    You need to send the watch into Suunto for service. The watch is obviously having an issue if it will not hold charge with a new battery and the Altimeter is not working correctly.
    The Altimeters are Barometric pressure related and occasionally something goes wrong.
    My experience is that Suunto is very good about fixing and/ or replacing when this issue arises.
    Jan 24, 2011 | Suunto T6c Heart Rate Monitor and Fitness...
    I have a suunto stinger dive watch after i changed the battery the ACW stays on the screen .
    open watch again and press tiny reset 'button' with a pin. That's how I fixed the same problem
    Jan 11, 2011 | Suunto Replacement Strap - Stinger...
    I HAVE A LUMINOX 3100 I THINK IT LOOSES TIME IS THIS A SIMPLE FIX?
    If any battery operated watch starts losing time or displaying the incorrect time, this is usually indicative of a battery going bad and needing replacement. My Luminox 3100 started lagging in time and I noticed that the second hand would intermittently stop. I also have a Suunto Vector (Digital) wrist-top computer and the times along with the compass, altimeter, light and alarms all started to act crazy and all it happened to be was the battery being run down. Coincidentally the Suunto has a battery gage that only appears and flashes during low battery charge.
    BL: Try the simplest thing first, change your battery. Please be very careful not to break the O-ring on any watch that's waterproof/resistant as this will render the protection useless. Also if your watch is still under a manufacturer or vendor's additional warranty, get them to change it as not to void your warranty. 'Hope this helps!
    Dec 04, 2010 | Navy Seal Luminox Dive Watch
    My Suunto Vector Watch was in storage for a year or so and had no display when I went to use it. I relpaced the battery with a new one (checked it with a voltmeter to ensure it was good) and still no...
    mcdevito75 here, Double check the battery install, make sure all contacts are clean, with the watch open see all buttons depress and are hitting points on the movement. When done, presss the mode button and display should come up.
    Aug 09, 2010 | Suunto Vector Wrist Watch
    Finding serial number of a Suunto Vector Watch
    mcdevito75 here, Contact the Suunto Company useing the contact info supplied in the box the watch came in.
    Jul 10, 2010 | Suunto Vector Wristwatch
    How to change the battery to suunto d9
    mcdevito75 here, With the tools and time needed, best bet is to look for a small watch repair shop in your area to change the battery.
    Jul 07, 2010 | Suunto D9 w/transmitter...
    T6C failed after working OK for 1 day
    Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
    If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
    To re-pair the belt:
    1. Remove the belt battery
    2. Push the (new) battery into the compartment positive side down.
    3. In your Suunto t6c, enter the settings menu and enter GENERAL.
    4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
    5. Scroll to HR BELT with [Lap +] and [Light -].
    6. Activate pairing with [Mode].
    7. Put the battery in with the positive side up and close the cover.
    Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
    Suunto X6 (black) Wrist Watch Logo
    551 people viewed this question
    Top Suunto Watches Experts
    Ansel Alberto
    Ansel Alberto
    Andrew Taylor
    Andrew Taylor
    Are you a Suunto Watch Expert? Answer questions, earn points and help others
