Question about LaCie (300728U) 250 GB Hard Drive
Hi I am trying to connect my hard drive and when I turn it on my computer doesn't recognize it and the light blinks yellow or green and red
    Sergeant:
  • 203 Answers
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Posted on Aug 31, 2010
The green light on front of my HP computer comes on for a couple seconds and then it goes to red light blinking and beeping try to turn off and back on several times and go right back to blinking red
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 04, 2012 | Computers & Internet
The green light is flushing but nothing else happens. The connected laptop doesn't recognize the maxtor hard drive. 12 V 2A is fine. What else can I do or check?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 18, 2011 | Maxtor BASICS Personal Storage 3200...
I have a Toshiba portable external hard drive that I am trying to hook up to the USB port on my tv but the tv says "devise is not connected". The light is flashing on the hard drive. Why...
the drivers might not be installed for this device check the leads that attach to your external hard drive make sure connections are good and leads are good
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Sep 13, 2011 | Toshiba Canvio Basics Portable 320 GB USB...
Hi , I'm having problem with my WD 500 GB external hard drive.My laptop and computer can't recognize the drive icon anymore and no usb connection icon is recognized by windows task bar.I have tried...
hope this helps you
Sep 01, 2011 | Western Digital Computers & Internet
My LaCie hard drive's light doesn't turn on or blink when I plug it into the computer
hope this helps
Sep 01, 2011 | LaCie (300770) 250 GB Hard Drive
Loaded everything onto drive, now computer doesn't recognize drive when connected.
hope this helps
Jun 25, 2011 | Iomega HDD Portable (32379) 30 GB Hard...
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
Jan 29, 2011 | LaCie (300728U) 250 GB Hard Drive
Blinking lights and not recognized by computer
Try to remove the internal drive from enclosure and connect directly to PC. Does it show up this way?
Does it make any new clicking/knocking/whirring/grinding sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
Nov 04, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Hi anaesaror.........
What version of windows are you using, XP with SP3 should see and recognize pretty much any USB drive out there, especially a cruzer, look in control panels | system | hardware | Device Manager for anything weird going on, there should be no yellow caution signs or red X's if you see the yellow caution sign, it means you will need t update your OS or find a driver, if the device has a red X over it, right click and try to enable it.
ZXR
Jul 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
LaCie (300728U) 250 GB Hard Drive Logo
128 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
