Question about PNY Technologies GeForce 6200 128MB AGP Graphic Card
I have a PNY 4gb usb drive, i had put some data on this long back, now when i'm trying to access this its not beong recognised. i have a windows xp machine
sandy_s
  • 111 Answers
SOURCE: Deleted files from my PNY 4GB flash drive are still taking up space.
Most flash drive comes with its on date support files on it. If those had not been removed then, yes it will show some space used.
Posted on Sep 09, 2008
ashishd19
  • 35 Answers
SOURCE: Need Windows ME Driver for PNY USB 2.0 Flash Drive Attache
Here's what you can do,
Download the files using the these links,
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbauth.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbhub.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbmphlp.pdr
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbntmap.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbstor.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbui.dll
Put all these files in one folder and when windows ask for the drivers, select the option to manually serach for the drivers. And point the search to the folder where you saved these files and it should fix the problem.
If this does'nt work, please let me know.
Posted on Nov 26, 2008
SOURCE: PNY 4G USB 2.00 Flash Drive
Solution:
i) try connecting it on the USB port present at backside or back panel of your computer tower, sometimes USB port present on the frontel panel of your computer might malfunctione or not working properly........
Posted on Dec 28, 2008
Damilare
  • 358 Answers
SOURCE: pny attache optima pro 8g usb drive disk space problem
Yes, and Perfectly too.
What you should do is,
depending on your operating system,
Right-Click on 'My Computer Icon', then select 'Manage'.
When you get to Computer Management page,
Click on Disk Management on left hand side,
This will display ALL the disks installed on your system, either partitioned or not partitioned, formatted or not formatted.
Then go to the ones that are hidden, not created, or not displayed, right-click on it, then you'll see different actions that you can perform.
Also, in some instances, what you just need to do when you get to this page is to assign a new, distinct, drive letter apart from the ones already in use on the system.
This will automatically bring out the hidden drives.
Hope I have helped you out.
Goodluck
Posted on Oct 31, 2009
Testimonial: "Thank you so much! This fixed my problem and I now can use 7.5Gb of my flash drive!(I do wonder why it says 8Gb, but I can only use 7.5)Again, thanks!"
SOURCE: i had a problem in my pny 4gb pendrive.I inserted
just go to the start->run->devmgmt.msc->go to storage device->ull find the universal serial ports, uninstall all the serial ports. restart ur computer. It will automatically installed all the serial ports again. Then insert ur pendrive. keep format dat.
Now ur pendrive is ready to use
Posted on Nov 05, 2009
Not enough space
Try to copy all data of PNY 4gb usb flash drive to your desktop or laptop.then format the usb.please see attact picture.
Apr 27, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I had data on my drive now it says it is not formatted
I would download a data recovery software programme if the data is important, you can get some f these as shareware or free if you look around.
As long as the computer can recognise the drive, you will be able to get the data back
As to why it is appearing as not formatted could be down to a number of reasons, commonly, transferring a usb drive to a mac and back causes these issues, or, the drive may be failing
Feb 07, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have a 4GB data traveller which is not recognised by any computer which I have tried i.e. XP & Windows 7. The error message is "USB device not recognised"
Your flash drive seem to be faulty,because you try it on more than one computer and you get the same problem,you should replace the flash drive.
Aug 17, 2010 | Computers & Internet
I have 3 pendrive first & second pendrive of transcend & croma is not recognised pny 4 GB pendrive it shows (please insert a drive into F)
try using this software to format the transcend pendrive . use it in XP or Vista www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
Aug 14, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Need driver for pny 4Gb Pendrive. It is saying Please insert disk when i try to open my pendrive. it is displaying in Devise manager.
Normally most of the pen drive are plug and play means the hardware is recognised automatically by windows.
Try the following steps below:
>start
>setting
>control panel
>administrative tools
>computer management
>in left column click disk management
>then you can perform format according to your choice.
ok try this and let me know
Any other help, you are most welcome
Regards
Uttam
Jan 26, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Pny 4gb pen drive is not working
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 02, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have a PNY 4GB high speed USB Drive. I want to
Well, the easy way would be to do this
But if you want to use the USB drive just insert it into an open USB port
  1. click Start
  2. click My Computer
  3. Select the USB drive from the list of connected drives
  4. Click and drag the files from their location to the USB drive
To get them to the other computer follow steps 1-3, then click and drag them from the USB drive to their new location.
Sep 16, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Solution:
Nov 20, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Unable to access files on the flash drive
SDHC cards are not backward compatible with normal SD cards..therefore older devices will not recognise them...your built in card reader is probably not sdhc...try downloading directly from camera or use a sdhc usb card reader
Apr 29, 2008 | PNY 4GB Secure Digital High Capacity...
Computers & Internet Logo
101 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
