Question about D-Link AirPlus DI-524 Wireless Router
DI 524 Frequent Wireless Network Loss
I have my DI 524 configured for my home network. Now the challenge is that the wireless network is lost in about 2 hours frequently. Whenever this happens, I have to reboot my DSL modem as well as router.
My connection is WEP enabled and laptop and router are very close to each other without any obstructung walls. Also there are no cordless phones in the house.
After I reboot the router, the connection works fine for another couple of hours and then again the same. Customer support suggested me to upgrade the firmware, but still no success after upgrade. Im I missing out anything in the settings?
Any help is much appreciated.
Regards,
DRP
  • maxscali Jun 27, 2008
    I have the same exact problem, so I think this not to be so strange.
    In fact I used this router very deeply for 2 years, with no problems, and now suddenly this problem appeared. Maybe It's a problem of wear and tear?
    Changing the channel of trasmission didn't change anything...
  • D-Link Master
  • 6,487 Answers
Try changing the channel of your router ex (channel 1-6-11). Since you upgrade the firmware of your router you need to reset it to factory default and reconfigure everything so the new firmware will take effect.
Posted on May 09, 2008
How can I connect the ps3 to a wireless router di-524?
First, you need to configure the wireless adapter inside the D-Link router:
* set an SSID -- the "name" of your network
* set an encryption-level -- use 'WPA' or 'WPA2'
* set a password for your network.
Then, enter the SSID and the password on the PS3, to connect to your wireless network.
May 14, 2011 | D-Link AirPlus DI-524 Wireless Router
Wireless repeater
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Pleaseremember that D-Link AirPlus G wireless devices are pre-configured toconnect together, right out of the box, with their default settings.Fora typical wireless setup at home (as shown above), please do thefollowing:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4)If you are connecting a desktop computer to your network, install theD-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCIslot on your desktop computer. You may also install the DWL-G520, orthe DWL-520. (See the printed Quick Installation Guide included withthe network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6)Install the D-Link DFE-530TX+ adapter into a desktop computer. The fourEthernet LAN ports of the DI-524 are Auto MDI/MDIX and will work withboth Straight-Through and Cross-Over cable. (See the printed QuickInstallation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
TheHome>Wizard screen will appear. Please refer to the QuickInstallation Guide for more information regarding the Setup Wizard.
Home > Wizard
Thesebuttons appear on most of the configuration screens in this section.Please click on the appropriate button at the bottom of each screenafter you have made a configuration change.
Home > Wireless
SSID-Service Set Identifier (SSID) is the name designated for a specificwireless local area network (WLAN). The SSID’s factory default settingis default. The SSID can be easily changed to connect to an existingwireless network or to establish a new wireless network.
Channel-6 is the default channel. All devices on the network must share thesame channel. (Note: The wireless adapters will automatically scan andmatch the wireless setting.)
WEP- Wired Equivalent Privacy (WEP)is a wireless security protocol for Wireless Local Area Networks(WLAN). WEP provides security by encrypting the data that is sent overthe WLAN. Select Enabled or Disabled. Disabled is the default setting.(Note: If you enable encryption on the DI-524 make sure to also enableencryption on all the wireless clients or wireless connection will notbe established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
I have a D-Link AirPlus DI-524 i want to use it wired only for to comps running win 7 i had a friend set up a wireless network before but had falling out so i need help to set it up as wired
For a wired network, the easiest way is using the Wizard mode (There's a botton named Wizard at Home tab), basically you'll have to configure connection with cable modem (WAN part) and check DHCP settings (LAN part), this one should be enabled for having automatic IPs.
Feb 21, 2011 | D-Link AirPlus DI-524 Wireless Router
Using DI-524, can't find the wireless network
Have you properly configured the web based Wireless configurations of the router? Also check WLAN IP configuration of your laptop. Configure WLAN IP configuration to DHCP and try again.
Regards;
Hassan
Jul 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Want to know the pre shared key
If you don't know your pre shared key or forgotten it. You need to access the configuration page of your router and create a new network name and a sign a new network key or pre shared key. Create the profile of your SSID/Wireless network connetion under wireless settings.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Setting code
i can not acess to my moderm
Jul 29, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
214 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
