Question about Dehumidifiers
I have a b and q bqdd122fw and will no extract water
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Sep 09, 2010
The fan on my bqdd122fw is not working check light comes on all filers are clean and tank is empty and secure
the fact that the fan wont run , is a tip off that (barring the fan has gottn stuck) the water collection bucket float switch has gotten out of adjustment , this might require a little trial and error to see just what posisition this little device needs to be in for the unit to run
Dec 17, 2014 | Dehumidifiers
RUNS BUT NO WATER
How humid are the conditions? if dry, will not extract water, can only extract water from humid conditions
Aug 05, 2014 | Haier HD306 Dehumidifier
LD451EGL no water extraction
Apparently, the fans are running, but the compressor has shut down. It could be a failed compressor, or the charge in the system could have leaked out causing the compressor to shut down.
Aug 01, 2014 | LG Electronics Ld451egl 45-Pint...
I have a goldstar DH40 , just bought it at a yard sale -
Give it a good cleaning before you do anything else. If the fins or filter are dirty, you won't get good service from it. Make sure the drain path is open.
Feb 05, 2013 | Goldstar Dehumidifiers
The motor seems fine, but it no longer collects water or helps the clothes dry. It is an Airforce model BQDD122FW. If it is the heater element, how much should it be to repair, roughly?
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Feb 20, 2011 | Dehumidifiers
Dehumidifier does not extract water. Fan works and I've cleaned and checked all connections. How do I tell if tis a bad compressor or coil?
It could be a abad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers that run but do not extract water from the air..
heatman101
May 03, 2010 | Whirlpool AD25BBR Dehumidifier
I have an Airforce BQDD122FW Dessicant Dehumidifier. When I bought it last year it worked OK. I have started using it again this year and although the motor appears to run normally it no longer collects...
Hi There, you have faulty heater inside. They are all the same Delonghi, meaco, Logik, ecoair .Airforce
I have done 100s now. If you good you can just twist the wire in the heater and will go again without any problems.
Its just basic steel wire twisted like a spring.
anyon eneeds help sam on 07590 057545
Oct 24, 2009 | Dehumidifiers
Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Jul 27, 2009 | Kenmore 54501 Dehumidifier
Delonghi DE220 dehumidifier stopped extracting water from the air
You probably have a dirty heat exchanger. Write to me at j_sjohn@hotmail.com for free maintenance instructions on a smilar unit. Cheers.
Dec 27, 2008 | Dehumidifiers
Dehumidifiers Logo
290 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
