Question about Goldstar MA-782M Microwave Oven
Is there a reset button on the goldstar ma-782m I was boiling an egg and now it won't come on
  • Goldstar Master
  • 3,740 Answers
No there is not a reset button. Most of the time when the microwave is in use and just quits either the Power Diode or the capacitor has failed and blows the fuse inside the cabinet.
With the unit unplugged and the chassis cover removed the fuse will be located at the end of the power cord lead in a fuse holder. The fuse is usually a 15A 250V slow-blo fuse. Just replacing the fuse will normally result in the fuse failing yet again.
STOP! Before going any further you must hold a well insulated screwdriver back on the handle and short across the High Voltage Capacitor at least 3 times! Failure to do so could be the start of a very bad day in the form of a horrible shock.
Next you disconnect one side of the cap including the power diode wire. With an analog meter set on R x 1,000 read the Cap terminals watching for a jump. Reverse the meter leads on the terminals and watch for a jump EACH time you reverse the test leads on the CAP terminals.
No jump = bad cap.
Constant resistance across the cap = bad cap
Lastly you check the power diode with the meter on the same settings R X 1,000. One direction will read full continuity (ZERO) and reversing the leads will read infinity. (no reading)
If the diode reads open both ways = failed
If the diode reads (ZERO) both ways = failed
It must read continuity in ONE direction only.
After finding and replacing the failed component then you can change the fuse and test the microwave.
There is a very very remote possibility that a door switch has failed but given that your microwave failed while in use I seriously doubt you have a door switch problem.
As far as finding replacement parts for your microwave nearly every appliance parts store will have what you need if you walk in with the failed part in hand. Most of the time they will walk back and grab the part you need without even digging in the parts books.
Thanks for choosing FixYa.
Kelly
Thanks
Posted on Aug 31, 2010
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
Turn table won,t turn
check and see if the turn plate is on correctly
Feb 25, 2010 | Goldstar MA-780M Microwave Oven
How do I defrost on my Goldstar MA-780M microwave oven?
Here is a link to download a users manual. It should give you the info you need:
http://safemanuals.com/user-guide-instructions-owner-manual/LG/MA-780M-_E
Hope this helps...
Sep 15, 2009 | Goldstar MA-780M Microwave Oven
Goldstart Microwave Model #MV1526 1000w Everything works, but does not heat up. Goldstar MAL 783W Same problem as for another Goldstar I saw here. light comes on, turntable turns, and to answer the...
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
The service manual can be downloaded here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
Dec 27, 2008 | Goldstar MA-782M Microwave Oven
Do you know what the wattage is of the Goldstar MA-685M Microwave Oven? I checked the back panel and the door panel and it is not listed there.
600 watts, according to the repair manual.
Sep 27, 2008 | Goldstar MA-685M Microwave Oven
Goldstar ma-780m
The tray is LG # 3390W1G005.
Here's the link to where you can find it... www.microwaveglasstrays.com
Jun 23, 2008 | Goldstar MA-780M Microwave Oven
Goldstar MA-1164M Microwave oven connected to 220 volts
We see this a lot. The problem is on the control panel assembly, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Jan 26, 2008 | Goldstar MA-1164M Microwave Oven
Wattage
The output power for model MA-780 was 700 watts, so I'd bet yours is either 600 or 700 watts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 02, 2008 | Goldstar MA-782M Microwave Oven
Microwave oven is noisy during use
Sounds like you have a failing turntable motor. You can contact LG / Goldstar about parts or service at 800-222-6457.
Apr 07, 2007 | Goldstar MA-790W Microwave Oven
Goldstar MA-782M Microwave Oven Logo
182 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
